How do I get the front axle LCA bolts out?
rkwfxd
Rich
Whittier
2021 JLR, 2020 Tahoe 4x4, 2006 Tundra, 1990 964
Unemployed
I purchased axle (Rock Hard 4X4) and frame (Rusty's Off Road) side LCA skids. Rear, axle side no problem. Rear frame side no problem. Front axle side - BIG problem.
Those factory bolts will not budge. I even bought a new Bauer corded impact driver that puts out over 1000 ft/lbs of removal force and those nuts are NOT coming off.
Any tips or suggestions?
Thanks
jahysea
Napa
00 TJ (sold), 08 JK Rubicon, 21 4xe Rubicon
Heat it. Might have threadlock on it. Long wrench or ratchet. I have a breaker bar that is 24” long that I have supplemented w metal pipe at times. Slide the pipe onto the breaker bar to increase leverage. Archimedes is your friend.
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
Are you holding the other side?
How about a 24” breaker bar (or one with a pipe extending off it at least) and using a floor Jack on it (carefully of course ?)?
rkwfxd
rkwfxd
Rich
Whittier
Unemployed
Im using a basic wrench to hold the other side but it doesn’t feel like much force is coming through.
Impact on bolt under vehicle and wrench on nut by tire.
Not sure if removing the tire will allow me to put the impact on the nit or not. If that even makes a difference.
The others all came right off.
rkwfxd
rkwfxd
Rich
Whittier
Unemployed
TKL223/3
Jon
Arkansas
Jeep JLU Rubicon
I used a Bauer and it never loosened any of my front lower control arm bolts. Got my Milwaukee impact wrench and it had no problems taking those bolts off.
Goosed
Ohio
2020 JLUR
Snap-On wireless impact gun for the win.
JasonInDLH
Jason
MN
Like @jahysea mentioned…it probably has permanent threadlocker on it which should be heated to 500 deg F prior to removal if you’re having a hard time budging it.
rkwfxd
rkwfxd
Rich
Whittier
Unemployed
Well shoot. Not super excited about using a blow torch on my brand new Rubi or spending even more $$$ on another impact wrench.
Gripster
Graham
2021 Rubicon 2D
Have you tried your leg muscle pushing on breaker bar? That was my technique.
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
I also had this problem so glad to hear suggestions. I was afraid to snap a bolt with a bigger impact.. didn’t think of threadlocker/heat.
I will say I tried a smaller dewalt impact with no luck on some other arms and was able to break them with my 24” breaker bar, so leverage does work!
Guess I’ll try heat then breaker bar on the fronts..
Roky
Roky
Thanks
Make the investment, it will make your wrenching life so much better.........
Jeep Wrangler JL How do I get the front axle LCA bolts out? 632D3986-D4FE-4578-8539-F1C94087D4E0
Everything else is just a toy.............;)
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
Here's my toy:
Jeep Wrangler JL How do I get the front axle LCA bolts out? snapon1
