There are exactly two treatments in each bottle.I wish I could use better diesel but in PA we get crap. Concerning the extreme, how much do you add every 6K?
What I was thinking, so if I grab some today and use for the first time just use 1 ounce for whole tank? Says 1 per 25 gallons but can use more?I use the EDT and I usually fill up at half a tank or 1/4 at a minimum. I do a 1/2 ounce when I fill up at a half tank.
That should be fine. You can use a little more than necessary, in fact I think it even says so on the bottle although I can't recall their wording right now.What I was thinking, so if I grab some today and use for the first time just use 1 ounce for whole tank? Says 1 per 25 gallons but can use more?
Same. And my fill up is usually 12-13 gal.I am using an ounce of EDT at almost every fill up on both hers and mine.
2 products being talked about in this thread. It is confusing. You did the right amount of diesel extreme. 8/20. EDT is something else, Everyday diesel treatment.Uhh I used slightly less (~7.5 oz) when I filled my 18 gallon tank today?? Itās my first time using.
I understood the bottle to say 8 ounces / 20 gallons?
I hope I didnāt screw up and have to drain it
Whew thatās a relief. Thanks for clearing that up.2 products being talked about in this thread. It is confusing. You did the right amount of diesel extreme. 8/20. EDT is something else, Everyday diesel treatment.
