Dr. RGB
Yes you are reading that correctly. Unfortunately this seemed to have no significant effect on coolant, oil or transmission temperature which is what I was hoping for. Even though temperatures were a bit lower without the vents I felt it was pretty insignificant.
***Warning: Stats Geek Thinking***
So, data are data and can be relatively useless unless we know if the data are statistically significant. I would recommend running a repeated measures t-test to indicate if the temperature differences are statistically significant or not. You can download JASP (free statistical data analysis program), formatting your chart for .CSV and run the analysis. This would give us a better understanding if the changes in temp are truly affected by the vents or if there are other confounding variables (remember extraneous variables become confounding when they influence the variables being measured, here it would be temperature).
