shmpls
- Scott
- Sep 6, 2018
- Minneapolis MN
- 2018 JLU Rubicon, BMW M4
Just got my two pairs of Rigid D-SS Pro spots (model #262213) and got them mounted up on the Artec Industries dual a pillar mount (http://www.artecindustries.com/JL_Single_LED_Apillar). Install was super easy, probably took about 90 minutes but only because I was meticulous about the wiring.
Originally I had intended to do a mix of spot + driving on each side to get better coverage. Getting the lights was a huge PITA, had one Amazon vendor no-ship a set, and another vendor send the wrong lights, so it took 4 orders to get the 2 pair of lights and ended up getting two pairs of spots once the dust settled.
I just went out and found some completely dark open stretches of road, and holy hell, I was blown away.
Not only do 4 forward facing spots throw a beam a long way, the coverage is blanketing. I expected more of a gap in the short range, but it is pretty much daylight from ten feet in front of the bumper to as far as you can see with no hot spots. And with two sets of side shooters, that is 6 side facing led's on each side, it is complete daylight from the front quarterpanel out on each side.
EDIT: Pics attached of both side shooter and front facing. Disclosure, I adjusted the exposure after the fact to compensate for my iphone camera light meter. The halogens are so dim, the iphone turns the light sensitivity way up, and the Rigid were so bright it dials it way back. These pics after the slight adjustment represent very accurately what I was seeing with my eyes.
One thing to note, the lights are rated at 3.36 amps so I took a chance putting all 4 of them on the 15a aux switch, but it blew the fuse pretty quickly, so I swapped it over to the 40a Aux 1 and have had no problems.
Also, make sure you are buying them in pairs. Some of the vendors on Amazon sell two, but it is two individual
lights which have two led side shooters on both sides of each light. The true pairs come as a left and a right with three led side shooters just on one side of each light.
The part numbers for pairs are 262113 (flood), 262213 (spot) and 262313 (driving). Singles will be 262113 (driving). The same part numbers starting in 8 indicate white housings instead of black.
Driver's side side shooters
Stock halogen low beams + fogs
Rigid cubes on (with headlights and fogs, but honestly I turned my headlights on and off a couple times and you couldn't even tell if they were on or not when the LEDs were on)
