TrailSnail
- Josh
- Aug 12, 2021
- Gilbert, AZ
- '21 JL Unlimited Sport S
- Vehicle Showcase
- 1
I installed Holley's intake over the weekend and figured I'd do a post about it since I hadn't seen much prior to purchase.
Installation was simple and took under an hour. Like most things, it didn't go without a hiccup or two. The sealed airbox-to-filter-to-tube design takes finagling to assemble. Even once you get it figured out, it's not exactly an easy or intuitive process and by nature of the design, cleaning the filter will mean disconnecting the vac lines and IAT sensor and removing the tube from the inlet. I'm not sure why manufacturers are going to airboxes like these (the AFE on my last Tacoma was the same way) but it's much more of a PITA to service the filter than just removing a cover and undoing a single hose clamp. On the bright side, the filter is huge, nicely designed, oil-free, and Holley's design retains the factory "snorkel" piece and airbox inlet location. This means there is no more risk of water/dust inhalation than the stock airbox, but also that there's likely no practical drop in IATs either.
After installation, I took the Trail Snail for a quick test drive, hammering the gas a few times. Past experiences taught me to expect a slightly harder pull in the upper-mid RPM range, especially at WOT, some intakes even bumping the "grunt range" of the engine higher in the RPM band at the expense of low-end response much like a manifold with longer runners does on a carbureted engine. Nothing like that was observable. Similarly, I was hoping for the deep, throaty induction sounds most aftermarket intakes produce - even newer "sealed" designs with helmholtz resonators. But to my dismay, it sounded completely stock... no growl, no resonance, just "whoosh" as it was to begin with. The lack of what I expected to feel on the butt dyno, combined with stock-sounding acoustics, made my initial impression "well, this was a waste."
Later the same day I jumped in and just went about my business, almost forgetting that I had just installed the intake. I immediately noticed that it seemed different. I was of the opinion that my JLU already drove very well, but there was suddenly a notable increase in smoothness, for lack of a better term. It just felt "happy." The way in which power was being delivered from the very bottom of the RPM range through the low-mid range compared to before was quite obviously better. Wait, what!? I thought maybe I was imagining things. But the more I drove, the more impressed I was. The turbo seems to spool faster off idle and there's almost no observable boost lag under normal driving conditions now. From a dead stop, it smoothly and strongly scoots away with a quick and buttery smooth torque delivery until the 2.0 begins to get gassed out up high, just as before. whereas I was able to clearly distinguish where boost started building as the RPMs climbed before. It has a more linear and less "stagey" feel throughout the power band Further evidence of this was observed this morning, because I was surprised at how quickly and effortlessly I was building up speed on the same route I take to the office every day.
TL;DR: It doesn't feel faster or sound beefier, therefore, it won't tickle a boy racer's pickle. However, this is a surprisingly well-engineered and mature upgrade that enhanced the areas where the little 2.0 already shined, bringing more liveliness and refinement to power delivery down low where it's most useful.
500 MILE UPDATE
As the Jeep's computers have adjusted to the new intake over time, power has continued to improve considerably (in the same areas noted before). Believe it or not, I can even hear a sucking sound that wasn't there before, indicating the PCM is actually allowing it to breathe more. I am absolutely impressed with the performance - specifically, with how and where the improvements are found. From idle to over 4,500 RPM, it undoubtedly runs smoother and revs quicker than stock despite the weight and rolling resistance I've added. It takes off like a little brick-shaped rocket on 35s eagerly and effortlessly from a red light. Power delivery is noticeably more refined and the Jeep is just happier feeling overall. Hands down, this is the most pleasant and well-engineered CAI I've ever owned.
500 MILE UPDATE
