Eye bolts and ratchet straps for me as well.. works great!I like the Harken hoist, of course that was before they became out of stock. Plan to build my own. >$40—
I've had a RinJ for a year or so. I initially liked that you can break it down for transport/storage but it needs to be updated to make it more sturdy, have sent this feedback to them. The round poles/construction design allow for movement at all the joints no matter how tight you bolt it together so you can twist the top 15deg or so horizontally from the wheel base/post axis and maybe 10deg rotation across the top left to right. It needs location pins or something to get rid of the assembly slop. It would not be nearly as problematic if it used square tubing. Like everything there are compromises... still here. Good idea implemented poorly. I can do both jeeps by myself with it though. YMMV.Well, I just ordered a RollnJack for myself, so we'll see how well it operates. I like that it is really just a jack. Easy assembly, and I can use it solo to lift the hardtop off of my Jeep. I don't plan on leaving the top resting on this device for the entire summer, however. It has enough clearance underneath that I can then place the hardtop safely on a scaffold I currently use as a shelf for it.
Since getting the 2-door, I usually enlist my neighbor to help me lift and move the top on to the scaffold, but he always seems to get a minor scrape or bruise during the process, and we've put some scratches on the Jeep as well. This will hopefully reduce any reliance I need on a 2nd person to help.
I hadn't heard of the RollnJack until I saw this post, and it looks to be the most stable. The ratchet/handbrake system on the Top Lift Pro seems problematic to me, and I don't like the idea of my hardtop swinging and swaying around on some straps like on the Lange. Same reason I don't feel comfortable with a ceiling hoist.
Hmmm, good to know about the stability. Thanks for the tip.I've had a RinJ for a year or so. I initially liked that you can break it down for transport/storage but it needs to be updated to make it more sturdy, have sent this feedback to them. The round poles/construction design allow for movement at all the joints no matter how tight you bolt it together so you can twist the top 15deg or so horizontally from the wheel base/post axis and maybe 10deg rotation across the top left to right. It needs location pins or something to get rid of the assembly slop. It would not be nearly as problematic if it used square tubing. Like everything there are compromises... still here. Good idea implemented poorly. I can do both jeeps by myself with it though. YMMV.
Yep the window can't close while on the lift... not much of an issue here but it would be nice to lower it for storage while on the lift.Hmmm, good to know about the stability. Thanks for the tip.
I also didn't initially like that the rear window needs to stay up if you intend to use the jack for storage too. That would necessitate a bigger footprint.
But neither of these should be big concerns for me since I'll be using the scaffold for long-term storage. The top stays off for about 6 months; I put on a TrekTop for the warm months.
