Hinge corrosion - affects certain colors?
If you are experiencing hinge corrosion, what color is your Jeep?
  • Total voters
    96
rkeen81
2019 JLU Rubicon/2023 JLU Rubicon 4xe (Hydro Blue
Yeah you would think the tailgate also and the hood and windshield hinges. But then why the edges of the doors and the front edge of the hoods?
Mine only has the bubbling on the hood hinges. All others are perfect. 2019 Ocean Blue.
Vito92
Isaiah
Detroit
2022 Wrangler JL 2Door Willys
Not sure what paint color would have to do with it. It's galvanic corrosion caused by aluminum in the doors coming into contact with the steel of the hinges. It would be a lack of a barrier coating between the two i.e. the primer. I still don't know why they haven't just placed a thin rubber gasket or similar between the two and been done with it.
Maybe perhaps the pigments within the paint and whatever the chemistry is with the primer and metal. Paint can get very very complex. Just my thoughts
Mines on the windshield but it's seems like it could be over spray to I'm not sure
Mike_Hawk
Illinois
2022 GOBI JLUR 3.6
Mechanical Engineer
What hood is fiberglass?
And the hinges nor the tail gate are steel.
These are extremely strong magnets millimeters beside my tail hinge.
Interesting... Isn't the whole issue about the hinges being steel and the doors being aluminum, or is that totally not how things are?
JeepViking13
Northeast
www.youtube.com
2022 Willys Xtreme Recon 2022 Ford Bronco
I recently (3 weeks ago) picked up a new 2022 Gobi Rubicon and the hinges have a thin gasket between them and the doors. I'm not sure if this is a new thing they started doing, but it's definitely visible.
Oddly enough, there aren't gaskets on the hood hinges.
EDIT: After looking into it, there aren't gaskets on the hood or back gate because 1) the hood is fiberglass stamped steel, and 2) the back gate is steel which is the same as the hinges.
EDIT 2: It turns out I was looking at a replica hood that was fiberglass, the original is stamped steel. I'm confused on what material the hinges are now that someone posted a picture with magnets next to the rear hinges
Can you take a picture of this. I want to compare it with my Willys Xtreme Recon in Gobi to see if I have the gasket your talking about.
Mike_Hawk
Illinois
2022 GOBI JLUR 3.6
Mechanical Engineer
It's a bit hard to see in the pictures, but there's a slight gap and if you look really closely in person you can see a super thin layer of foam.
Jeep Wrangler JL Hinge corrosion - affects certain colors? 1661205985835
Jeep Wrangler JL Hinge corrosion - affects certain colors? 1661206017092
JeepViking13
Northeast
www.youtube.com
I'll take a look. Hopefully it's there.
Rico1111
Rico
RI
2018 Rubicon 2 door JL
I have very little on one of my hinges so far! But I did let jeepcares know about it a year ago and also my dealership. although I won't go the dealership route when it gets bad I'll take it to a good auto body shop for the paint work and I'll do the prep/gasket before hand.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Before mine bubbled or chipped, I did this.
JayJay
Johnny
North Georgia
'20 JLR
Got a magnet David? It's easy enough to check out. The hinges on my 2020 MY are non-ferrous.
Rico1111
Rico
RI
Now that's what I'm talkin bout!!! Why wait for FCA to take a turd on your rig when you can take the matter into your own hands.....yeah I get it $ but time is dollars and they waste too much of mine!
Dyolfknip74
2021 JLU Rubicon
I did it on my JK back in 07 with Duplicolour bedliner. Pretty sure I was the first to do it. Lol. It was solid on it 5 years later when I sold it. This time went with colour matched LineX
Rico1111
Rico
RI
When the time comes I'll be borrowing your Idea!!!! Great info Thanks!
Mike_Hawk
Illinois
2022 GOBI JLUR 3.6
Mechanical Engineer
Interesting, if that's the case, why even add the gasket if it's just aluminum on aluminum?!
