I agree with you, when I picked up my 392 XR it had 37 psi in all 4 tires and after a hour of driving this went up to 40 psi. I have always run nitrogen in my tires to combat this problem, one benefit of Costco. There are other ways to purchase it and it does make the tire run cooler and not suffer as much air loss due to being a gas that is more dense than aira lot of variables in tire psi. So try a psi and adjust. Remember 1 psi increase per 10 degrees increase in temp of air in the tire, on average. So I set to 30psi 1st thing in the morning when I check. That might get to 35-36 in The heat of the day on the hiway. It is cold here in the morning in my garage. You might be outside and in the sun in the AM when you check. I never want more than 35 psi in my tires at their hottest, so I adjust based upon highest psi.
Yeah, always should chalk test. For me, 32 psi was the right number on my KM3's. My KO2's I run at 27. Could just be weight differences or something, not sure. Both are D rated. 37" KO2s on my JTRD, 37" KM3's on my 392XR.I have a JLURD with a Mopar lift and 37" KO2's I started at 35 and then to 32 psi but when I ran over a puddle the tire track that it left was not a full tread. I am running 30psi now and thinking that might be still too much. I am going to chalk the tires soon the check it out.
The best part about a chalk test back in the day was you got to throw the eraser at someone.Yeah, always should chalk test. For me, 32 psi was the right number on my KM3's. My KO2's I run at 27. Could just be weight differences or something, not sure. Both are D rated. 37" KO2s on my JTRD, 37" KM3's on my 392XR.
or I'm terrible at chalk testing![]()
Yeah my 3500 HD SRW came filled to something stupid like 90. I mean I know for sure when you're towing you want more pressure and everything, but damn.The best part about a chalk test back in the day was you got to throw the eraser at someone.
I have seen guys use a spray bottle of water to lightly wet the tread down and then give it a roll over something flat, I have used a piece of plywood when I was not at my garage, but you are 100% correct in that every Jeep is set up differently and tire pressure is just part of the equation. My neighbor bought a GMC pick up and was running 75 psi in the tires, I swear you would loose a filling if you rode in that truck, he did not understand how to read the sidewall and just went to the max
Lower it to 32-36 tops. It’ll ride smoother.XR 35s, 300 miles in, dealer set them at 42. Been averaging 17 and some change mpg highway, uphill and downhill. Waiting for the temp to get to a more regular # then going to play with the psi
Read the thread title again.The one thing I forgot to ask you is, what motor is in your XR?
