2020 Diesel JL
- Peter
- Feb 22, 2020
- Debary FL
- 1955 CJ3B Diesel, 2018 Camaro Hot Wheels Convertible, 2018 Dodge 3500 Diesel, 2020 Harley CVO Tri Glide White, 2020 Harley CVO Tri Glide Black, 2020 Jeep Wrangler Rubicon Diesel
- Occupation
- General Manager / Owner of CraneWorks Orlando
- Vehicle Showcase
- 1
$170 New never installed or used. Would rather not ship but will if buyer pays shipping. Ideal for remote access with limited resources Marked with luminescent tape for use in IDLH and low light atmospheres 36 square inch, 360 degree rotating base for an array of rescue options Removable top clamp-clevis attachment is capable of winching, clamping or spreading up to 4660 pounds Durable bright yellow and red power-coated finish "Hi-Lift Jack - the versatile rugged jack putting you in command of situations that require lifting, pushing, pulling, winching, and clamping. Lightweight and easily to maneuverable, the Hi-Lift Jack's rated capacity is 4,660 lbs (2114 kg) with a tested capacity of 7,000 lbs (3175 kg). Hi-Lift Jacks are made with a two-piece handle and socket design that is built for extended life. Cheaper imitations use a one-piece design that bends easily if lateral pressure is applied while lifting a load. "
