FLECK-5
- Greg
- Oct 30, 2018
- Yardley, PA
- 2018 JL Jeep Wrangler Rubicon
Are you going to put bigger tires on it? If so, something to think about:
Rubicon fenders sit up 1” higher then the Sahara which means they can fit 2” taller tire with the same clearance inside the fender. Rubicons have 4.10 gearing so if can handle 35” tires without re-gearing.
35” tires need a 2” or greater lift on a Sahara but a Rubicon doesn’t need a lift for 35’s and the tires will look small if you lift the Rubicon and put 35’s in my opinion.
Putting a lift on a Rubicon = 37” or bigger tires depending on the tire size. Once you get 37’s or bigger, the expenses start jumping quickly.
If you want 35’s, get a Rubicon and don’t lift it.
