Help with new all season tires!!!
Alphawolf91
Zach
2018 Jeep Wrangler JLU
Will these fit a 2018 Wrangler Unlimited JL Sahara?
DUELER A/T REVO 3 LT275/70R18 LRE OWL ALL TERRAIN TIRE
Looking to beef up the look of my currently stock Sahara, and thinking of starting with the wheels.
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
I can't answer your question directly. however, I did something similar on my JLU. I recommend using tiresize.com as a tool for comparing potential tire sizes.
Hopefully Sahara owners can also chime in with their experience.
aldo98229
Aldo
Bellingham, WA
Market Research
My Sahara has 275/70R18 BF Goodrich KO2s: they are 1.1 inches taller and 0.8 inches wider than the OE 255/70R18 Bridgestone Duelers. They fit without a lift and without rubbing.
cat=110&_nc_ohc=dNjJTD-tFHIAQnLexmDSESJsYlQNs7TfKzkqKi7BmE8YkjvbTbfdXRLiQ&_nc_ht=scontent-sea1-1.jpg
cat=102&_nc_ohc=1EAA2ibq6mYAQnTrN5tR6VKjEWX9ZNHfTxZ087K6OKJVFNPqCSWE7hVWw&_nc_ht=scontent-sea1-1.jpg
See tire size comparison here: https://tiresize.com/comparison/
cat=101&_nc_ohc=b3iuE4VIq9YAQk9YgwdDkROVi2YxStA5Br9_cWrTA4jngaZ1NgI8o7Dsw&_nc_ht=scontent-sea1-1.jpg
PS - If I were to replace the OE tires with a larger set, I'd choose an All Terrain with a more aggressive tread pattern than the Bridgestone Duelers.
Alphawolf91
Zach
I am looking at the Duelers to save a little money due to Black Friday sales at Costco. How different would the tread be on the KO2’s you are using. The duelers look quite more aggressive than the OEM treads.
From what is being said, I would not be able to use the OEM wheels with these tires though?
is the a recommendation for larger tires that would not require new wheels as well?
thank you everyone so much for the assistance!
sanman357
Carl
L.I. New York
-*|||||||*- 19' Mojito! Rubicon 6-speed, 09' Ram TRX4, 67 Chevelle 300 Deluxe
A 275 tire will fit on a stock rim.
aldo98229
Aldo
Bellingham, WA
Market Research
Yes, you can re-use your OE wheels. That’s what I did. You won’t have issues re-using your OE wheels with 275/70R18 size tires.
This is the Dueler Revo 3
This the KO2
Only you can decide which one you like better.
Only thing I’d add is: there are at least three different tires sold under the “Bridgestone Dueler Revo” name. Make sure Costco is selling the one you want.
Good luck!
TrailJoy
Northern BC, Canada
2020 JLUS, HellaYella
I use 1010tires.com (tools and tech > tire size calculator). Punch in the stock size tire, then do a manual search to compare to the size you want to use. The speed variance needs to be under 3% (in Canada), but the closer to 0 the better. I wouldn't use those tires myself.
The left is stock. Right is your chosen tire.
Alphawolf91
Zach
What would everyone recommend that could be used on the OEM 18’s that would add some height and look?
shekmark
Manasquan, NJ
Yes
I was actually looking at Costco deals as well. My original plan was 35 in KO2's. Ten I started looking at more street friendly tires like Revo's and Cooper AT3 4S. My KO2's are slippery in the rain. I am going to try driving slower. I think a larger Bridgestone Revo would look good.
