Help with Halogen to LED Conversion
Party Marty
St. Louis, MO
2019 Wrangler Unlimited Sahara 2.0
Hi, all. New here. I updated the halogen headlights and fog lights on my 19 Sahara with no issues. I bought the DRL and turn signals below, thinking they were plug and play, but I’m getting a fast flash. The seller so far has offered a $10 refund to buy the necessary transistors to fix the issue, and has also mentioned updating the UConnect to denote LED turn signals. I don’t see that option on my 7” UConnect. Is there a place to update that setting? Or do I need the transistor? If so, what is that? I’m clueless. Thanks.
https://www.amazon.com/dp/B07RJDWD4X?ref=ppx_pop_mob_ap_share
Party Marty
Party Marty
St. Louis, MO
A resistor, or better yet, a programmer, like the Tazer JL can tell your computer those lights are now LED. That will stop the fast flash, and any light out warnings.
Whoa, that’s a big fix for a small problem. I was thinking that since the seller was offering a $10 credit there could be a $10 solution. Otherwise, I could just buy LED housings for less than the programmer!
Party Marty
Party Marty
St. Louis, MO
That Tazer looks cool, like I’d really like the advanced functionality, I’m just not sure I’m there yet.
jawest12
Aaron
WV
jeepinwv.com
2020 JLU Rubicon, 2018 JLU Sahara
The resistors would be the $10 solution and absolutely work.
jawest12
Aaron
WV
jeepinwv.com
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Can you point me to them? Thank you a million times.
Just a heads up with using resistors. They get hot enough to melt their way through plastic, so be careful with placement.
The Tazer would change the system to work with the LED's, rather than tricking the system into thinking there are still incandescent bulbs in use. Might be a worthwhile investment, especially if there's other features that interest you.
jdubya421
Jakob
Greensboro, NC
2020 Rubicon 2-Door MT V6
You should definitely invest in the Tazer. You will be able to change a lot with the Jeep and it will help with future upgrades like tires and gears.
Northridge4x4
Summit Sponsor (Level 3)
Silverdale, WA
www.northridge4x4.com
2016 Sahara JKU, 2013 Rubicon JKU
Seller of badassery
The nice thing about the Tazer is you can reprogram a lot of different things, it'll come in handy for future mods!
Adjust for alternate tire sizes up to 41″
Adjust for alternate axle gear ratios
Adjust for an alternate transfer case LO range ratio
TPMS menu:
Disable TPMS system if desired
Change front/rear TPMS warning PSI limit
Radio menu:
Disable Backup camera
Enable Cargo/front/undercarriage Camera input
Enable CD audio input
Disable TravelLink (weather warnings included)
Lighting Menu:
Change DRL region (type)
Change DRL location
Disable DRL Dropout
Enable Fog lamp output
Disable Fog lamp dropout
Disable Halo’s
Set LED 3rd brake light type
Set LED tail lamp type
Set LED front turn signal type
Set Trailer Tow output for use with Mopar kit
Other menu:
Disable/Enable Electronic sway bar – for axle swaps or to run disconnected at any speed or drive mode
Disable/Enable Front Axle Disconnect
Disable/Enable Front and Rear Lockers
Enable Aux switch settings on the radio
Enable Blind spot detection (sensors required)
Change cluster splash screen to Wrangler/Sahara/Rubicon
Enable/Disable PANIC button on remote
Live features:
Light shows: Can be accessed from the key fob or from the on-screen menu. 6 pre-set light shows and 3 make-your-own shows included. Set from the factory to only operate when parked, but can be unlocked for off-road, parade, and emergency personnel use.
Disable Navigation in-motion lockout – enter addresses while the vehicle is moving
Disable camera lockout – use the backup camera and/or added cargo/front/undercarriage camera at any speed for any length of time
Auto Traction Kill – can be set to turn off traction control upon start-up
Auto StopStart Disable – can be set to disable AutoStopStart upon vehicle start-up
AutoPark Disable – can override the AutoPark system
TurnCAM – can turn on backup camera whenever turn signals are used (great for when the doors are off)
0-30 and 0-60 timers
Cooldown mode – run engine fans when Jeep is off, to aid in cooldown
Winch mode – raise engine idle to 2000 RPM while winching or jumping another vehicle
Thanks for the order @Party Marty!
Party Marty
Party Marty
St. Louis, MO
So, a recap. I have a Sahara, it had the halogens, it has the 7” UConnect. I’ve replaced all the bulbs with LED’s and purchased a Taser to tell it so. I’ve updated the setting in the submenu to “Canada,” allowing for full time DRL’s (I thought), but still don’t have full time DRL. What am I missing? Or where can I check to ensure everything is loaded correctly? Thanks.
Clayton Offroad
