dragoneggs
- Mark
- Dec 14, 2021
- Seabeck, WA
- '22 Snazzberry Pearl JLR
- Build Thread
- Link
HELP!
I was finishing up installing a tailgate table w/LED light. Fished the wire through the harness across the back of the jeep cargo floor and decided to tap into the 12v outlet.
Was impatient waiting 24hr for some T-Taps to splice into the wiring and decided to solder the 22g wire into the existing wiring. I disassembled the connector and tried to solder the hot wire. Had a little spark... anyways realized I blew a 20amp fuse.
Replaced the fuse #43 for the battery operation only and still no power. The outlet does work with ignition on (Fuse #45). So, question is... what next?
I guessing a fried some wiring. Do I try to lift and remove the fuse panel? See what's underneath?
