daveprice7
- Dave
- Aug 26, 2019
- Junction City, OR
- 2019 Sport 2DR, 2020 Willys 2DR
- Occupation
- Nerd
I will be putting on springs/shocks from a JLUR soonish, and I'm anticipating my OEM Goodyears will start to look a bit out of place... so I'm shopping for rubber. I want a snow rated tire (I have to carry chains now) that's good for highways, gravel roads and offroad trails with maybe some shallow mud; I don't do anything technical.
I think I've settled on Wildpeak AT3Ws, but my questions aren't specific to this tire. I'd go with KO2 takeoffs if I could find a good price on them locally, but it's been a year and I haven't yet.
My main decision seems to be between these sizes in the Wildpeak:
LT255/80r17 (10 ply. 52.5lbs)
LT285/70r17 (10 ply. 58.9lbs)
LT285/70r17 (6 ply. 62.8lbs) (less ply, more weight??)
P285/70r17 (4 ply. 50.5lbs)
Here are my questions (not specific to this tire, probably):
10/6/4 ply? Since the JL isn't very heavy and won't be loaded with much more than, say, camping or skiing gear..... Is this metric really that important? I've read folks say 10 ply rides rougher, but.. does it also hold its shape better while cornering? Is 10 ply "all negatives, no positives"? or.. is it merely a cushy ride vs sporty ride decision? I would trade a smoother ride if there are some advantages.
80 vs 70 profile ... this one is a bit confusing to me since 285/70 and 255/80 are nearly the same diameters, there shouldn't be a very noticeable difference in sidewall height; so, things like cornering would be about the same, no? It seems it would just be the side profile that would be different; 255/80 would be a more "flat" sidewall and 285 is more donut-shaped?
Tire Weight... There's as much as 10+ lbs difference between these similar-diameter tires. Is 10lbs a lot for things like acceleration/MPG? I'm in a manual with 3.45 gears, so even going up a tire size will start to feel more sluggish... I don't want to exacerbate it with more unsprung weight than absolutely necessary... the 255 or P285, at about 50lbs are high on my list because of weight.
Size: 285 vs 255 .... I have a decent handle on the impact of tire width; skinny should be less rolling resistance (better mpg), cut through standing water better, less floaty on the road in general; probably better on snow... but worse in the mud or rocks (which are lower priorities for me). The advantages of pizza cutters seem to speak to me, even if I prefer the looks of wider tires.
Thanks all!
Thanks all!
