TroyBoy
- Troy
- Jun 14, 2017
- Vancouver Island, Canada
- 2018 JLUR
I haven’t been able to find any with an 18mm offset or largerAre you set on XD's? If not, look at Fuel Vectors in black...or, Method 305's. But, you're the one who has to look at 'em every day...
Just out of curiousity, why is 18mm or greater a requirement? Do you want them tucked in and not protruding? The Vectors have a -12mm which should give the wheel a bit of a "deep dish" look...but, it may stick out some as well...I haven’t been able to find any with an 18mm offset or larger
Yes mostly. I have my 12.5" wide tires on stock wheels right now and the side walls are already sticking out past the fenders. The tread may have an inch at the most before it sticks out too. So -12mm pushes the tire out 2.25" more and I would prefer an inch only. The laws here state no tread past the fenders and I would prefer to comply.Just out of curiousity, why is 18mm or greater a requirement? Do you want them tucked in and not protruding? The Vectors have a -12mm which should give the wheel a bit of a "deep dish" look...but, it may stick out some as well...
Im going with Fuel Assaults but not sure on tire yet ....Nitto / Ko2 / MTAre you set on XD's? If not, look at Fuel Vectors in black...or, Method 305's. But, you're the one who has to look at 'em every day...
I do like Fuel wheels but there is nothing close to the offset I was wanting.Im going with Fuel Assaults but not sure on tire yet ....Nitto / Ko2 / MT
might check-out tirerack.com as you can see most of these wheels, and many more brands, with a real JL photo now in their configurator.
