Help Identifying Mopar Part# For Mopar Lift Fox Rear 2.5 Shock
cavguy
Arizona
2020 JLUR
I need some help identifying the Mopar part # for a replacement Rear Fox 2.5 shock, the one that came in the Mopar 2" lift.
Note: I do not know the specs/model (2dr, 4dr, or engine) of the Jeep this came off of unfortunately....
Fox Part # 986-24-090
Mopar Part # ???
Jeep Wrangler JL Help Identifying Mopar Part# For Mopar Lift Fox Rear 2.5 Shock IMG_0373 2
Jeep Wrangler JL Help Identifying Mopar Part# For Mopar Lift Fox Rear 2.5 Shock IMG_0374
cavguy
cavguy
Arizona
2020 JLUR
That looks like grease not shock oil.
I greased the shaft of the shocks because they were squeaking (Fox rubber seals are very tight). One of the shocks is bad however...
cavguy
cavguy
Arizona
2020 JLUR
As mentioned, Mopar parts item.
Perhaps, but I see these shocks listed on mymoparparts.com but cross-referencing the Mopar 2" lift instructions I see two possibilities for the Rear shocks part # 68316582AC and 68316580AC but no indication of the Fox part # so I can't match them up to mine.
https://www.mymoparparts.com/oem-parts/mopar-shock-absorber-68316582ac
https://www.mymoparparts.com/oem-parts/mopar-shock-68316580ac
I've never heard of anyone having to grease a squeaky shock shaft.
See this thread for more info on shock squeak (or Google for more results) - I just used some synthetic weapons grease I had which is safe on rubber and plastic:
https://www.jeepgladiatorforum.com/forum/threads/mojave-fox-rear-shock-squeak-noise.51119/
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Mopar Part # ???
Aside from contacting Fox directly the only way I can help is to know what the lift kit part number is or 2 or 4 door and engine size. As you can see here there are 3 variants used
https://www.allmoparparts.com/docs/77072397AD.PDF
-Benny
cavguy
cavguy
Arizona
2020 JLUR
Ok so it does appear this shock is: 68316580AA or now 68316580AC
AllMoparParts.com
Benny
NY
2018 JL
