JP29
Morning everyone!
I've recently decided to undertake adding some significant mods to my '20 JL Sport - retrofitting in freedom panel brackets, adding an overhead molle panel, stealth light bar, popping out the airbag and cluster bezels to paint the body color - but the one I'm seeking help with here is how best to tie in some 12v to 5v usb power plugs. I have a few little devices that I'm wanting to give a clean install to, and I'd like to have them tied to ignition on. They don't draw much power. Initially my plan was to tie into the cigarette lighter power, but I've read in a few sources that there is an ignition on wire behind the glovebox. Any tips or tricks on which of these - if either - to use, and how best to make the connections? I bought an assortment of T tap connectors, which I've read can be unreliable unless you pre-score the wiring. They also aren't waterproof, but I figured if they're in danger of water ingress, I've got bigger problems. Any help appreciated!
