Riperoo
- Brian
- Aug 3, 2018
- Bucks County PA
- 2021 Jeep JLU Sahara Altitude Diesel
2021 JLUSD is the vehicle in question.
So I was installing a 12 volt socket (for a fricking xmas wreath) on my factory aux switch, nice clean install, or so I thought. Get it all done, go to fire it up and nothing. The Aux switch in the cab itself lights up, but the wired in 12 volt socket is dead, and when I went back into settings to check on things, I can't even see an option for the Aux switches in the setting options!?!?!?! They were there before I started as I checked just to see how they could be set up.
I did search on the forums and saw that this can happen and to just wait and it will come back, but then I took it for a drive and noticed that my heat settings only have Hi/Lo, not the degrees it normally had?!?!?! I am thinking that I may have, i don't know, shorted something out, that would surprise me, even though I did not disconnect the battery, I had the jeep off and had not even programed the Aux switch, I figured it would have been fine to work on. But it seems I may have been misguided and both issues may be related. Appreciate any input, from what I have been seeing it looks like wait till tomorrow and see if it all magically comes back, however, that is not in my nature unfortunately, but if I get that input here, I will do my best not to mess with things!!!
