hybrid3.0
How fast were you moving when you did your shift into 4wd HI? You have a Willys which comes standard with LSD so I think you locked the rear axle (like posted earlier) which caused loss of vehicle control. Let's assume a properly functioning transfer case, which may not be a good assumption considering your earlier discussion. When you shifted 'on-the-fly' from 2 HI to 4 HI, the transfer case locks both front and rear drive shafts and immediately attempts to spin the front driveline, which has been disengaged, to match the speed of the rear driveline at your current road speed. The inertial mass of your front driveline components being spun up to speed causes an abrupt counter force applied through the driveline to the rear axle which slowed both rear tires enough to "lock up" and lose traction and the jeep having a high center of gravity hit a snow bank or dropped off the shoulder and rolled.
It might be advisable in the future to slow to 5 mph or less, even coming to a complete stop at some safe location, to make any drive mode changes especially in ice and snow to avoid loss of vehicular control. I am glad you and the jeep are OK and hopefully this won't happen again. If your transfer case is having issues, this needs to get fixed immediately.
