marsh1
Did you ever get one installed? Thoughts?
Not yet. Other projects got in the way but it is on the agenda for tomorrow
Iām looking at purchasing this for my 392XR. Do you still feel itās worth it?Finally got around to installing the Hellwig. It is thicker and way heavier. I don't feel a difference in ride quality and much less body roll.
Yes! I agree, this is the single-best mod I've done to date. The on-road handling is so much better. I haven't noticed any difference offroad either, but most my off-roading is pretty lightIām looking at purchasing this for my 392XR. Do you still feel itās worth it?
Yes I have it and on a 392 it would be a no brainer. You wonāt be disappointed.Iām looking at purchasing this for my 392XR. Do you still feel itās worth it?
Use a generous amount of synthetic grease on the bushings. Probably need to repeat once or twice a year depending on the conditions you drive in.Love mine but its prone to really loud squeaking
I know this question is a smidge on the old side but I just came across it. This dude tested articulation with and without and he did better with the rear sway bar connected. Seems counterintuitiveHave you tried disconnecting the rear sway bar completely? Iāve tossed around the idea for articulation reasons, as the JL is the only Jeep Iāve ever owned (10+) that still has a rear sway bar on it. If ditching it helps with oversteer I can sell the wife on the idea as itās not just for wheel travel gain.
Wondering the same thing, so interested in responses.@Brosef and @marsh1 - I am super excited to see you both do this on your 392s!
I plan to install the sway bar kit on my 22' Rubicon 392 XR that arrives next month. I haven't seen any design changes between the 21' and 22' 392s that would make me doubt the sway bar kit will work.
I reached out to Hellwig but their Customer Support won't give me a straight answer yet.
Would you have any hesitations on ordering the 7775 sway bar kit if you were in my shoes?
I appreciate your thoughts!
0.875If I wanted to replace the bushings to greasable fittings like these https://www.autozone.com/suspension...-sway-bar-bushings-9-5165r/353704_0?rrec=true . Does anyone know what size?
