Heavy duty Jeep Wrangler JL differential covers
Thread Status:
Not open for further replies.
  1. RanchoShocks
    RanchoShocks Well-Known Member
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    Rancho® Differential covers for the JL are manufactured from high-strength nodular Iron for added axle and internal gear protection. Ribbed external construction for added strength. Off-set over-sized fill plug for increased fluid capacity and easier/quicker filling. Durable red powder-coated finish.
    Check with your favorite retailer on cost and make sure to grab a front glide plate too!!
    laraza2k1 likes this.
  2. johnparjr
    johnparjr Well-Known Member
    First Name:
    Vehicle(s):
    2018 Sahara unlimited JL
    Jan 7, 2019
    Roseville
    528
    Liked:
    493
    No love for the Sahara
  3. Arterius2
    Arterius2 Well-Known Member
    First Name:
    Jerry
    Vehicle(s):
    JLU Sahara 2.0L
    Dec 29, 2018
    Vancouver, BC
    2,221
    Liked:
    2,521
    #3 Apr 5, 2019
    Wouldn’t the rear D44 cover able to be used on a Sahara/Sport S with either MT or LSD?
    DynoMax Exhaust likes this.
  4. OP
    RanchoShocks
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    Correct but no 30/35 at this time.
  5. OP
    RanchoShocks
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    Interior image :)
  6. Hydroboy35th
    Hydroboy35th Well-Known Member
    First Name:
    Josh
    Vehicle(s):
    2018 JLR
    Apr 17, 2018
    Zanesfield Ohio
    337
    Liked:
    783
    Garage Profiles:
    Any forum discounts?
  7. OP
    RanchoShocks
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    So we don't sell direct at this time, but I am sure there are vendor's on here that DO offer forum discounts :)
    Thanks Matt
    Hydroboy35th likes this.
  8. Dogboyslim
    Dogboyslim Well-Known Member
    Vehicle(s):
    2018 JLU Rubicon Punkn.
    Aug 28, 2018
    Wisconsin
    275
    Liked:
    308
    Is the front glide plate compatible with this diff cover? Looking at the description of the slider, it says for OEM covers. Can you clarify if both can be used together?
  9. OP
    RanchoShocks
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    Yes they will work together!
    Dogboyslim likes this.
  10. Dogboyslim
    Vehicle(s):
    Aug 28, 2018
    Wisconsin
    275
    Liked:
    308
  11. CarbonSteel
    CarbonSteel Well-Known Member
    Vehicle(s):
    2019 Jeep Rubicon Unlimited
    Jul 21, 2019
    393
    Liked:
    281
    Garage Profiles:
    @RanchoShocks - No drain plug? I would expect to see one on every aftermarket cover. Is there a reason one was not designed in?
  12. OP
    RanchoShocks
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    Remember the front axle has a drain plug at the base (that should be protected by our glide plate ;) )
    We also know that many mechanics/DIYers like to pop that cover to inspect the interior.
    Lastly, just another possibility of getting hit by a rock.
    Thanks Matt
  13. CarbonSteel
    Vehicle(s):
    Jul 21, 2019
    393
    Liked:
    281
    Garage Profiles:
    Matt - are the covers for the 3rd Generation Dana® 44 HD Wide Front Axle and 3rd Generation Dana® 44 HD Wide Rear Axle the same ones as the 2018 JK axles?
  14. OP
    RanchoShocks
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    The JK and JL covers (and axles all around) are a different shape, but neither have a drain plug.
  15. CarbonSteel
    Vehicle(s):
    Jul 21, 2019
    393
    Liked:
    281
    Garage Profiles:
    Copy on the no drain plug, I was curious if they were the same cover between the two models. I gather based upon your answer they are not interchangeable.
    RanchoShocks likes this.
Loading...
Thread Status:
Share This Page
