Heavy-Duty brakes vs Rubicon brakes
Tdkrum5
Ted
WA/AZ
20 White JLU Altitude
My unlimited Altitude came with Heavy-Duty brakes is there and difference between these and the Rubicon brakes? I am looking for Rubicon axles and wondering if my brakes will work
Tdkrum5
Tdkrum5
Ted
WA/AZ
AnnDee4444
'18 JLR 2.0
AnnDee, bigger on the High Altitude or the Rubicon? What about the unlimited Altitude are they the same as the Rubicon?
Bigger on the High Altitude.
Sorry didn't realize you were asking about a non-High Altitude (and I didn't even know it existed). Disregard my first post.
Tdkrum5
Tdkrum5
Ted
WA/AZ
They’re the same brakes if they are the HD Brakes.
Thanks, When i looked this up on Mopar parts it says the HD brakes are only for the sport and Sahara. Does not say they work on the Rubicon.
Storey21
Trish
Victoria
2021 Rubicon 4 door
I’ve been researching brakes lately because I need to do mine. Found some interesting things. Sport models are BRY, Willys/Sahara/Rubicon are BR6. High altitude models like yours are a BR5 brake code.
Kijijeep
Canada
2021 Xtreme Recon and 2017 JKU Sport
The heavy duty brakes on my Xtreme Recon have "392" embossed on the rear caliper brackets. Take a look and see if it says that on yours.
Jeepstrangler
Oregon
2018 JLU Rubicon
I’ve been shopping for brakes as well. Everything I find for my Rubicon is the same size rotor as I currently have 330mm front and 342mm Rear. All the brake kits I seem to find aren’t any bigger or better. At best you get a painted caliper and cross-drilled rotors. If anyone has found a better kit to upgrade a rubicon id love to hear from you. I’ll look into the high altitude if the rotors are bigger.
Zandcwhite
Zach
Patterson, ca
2019 jlur
https://www.powerstop.com/product/jeep-big-brakes/
343mm front rotors and 360mm rear. At $1,200 from 4wheelparts, it's definitely the cheapest big brake kit on the market. Alcon and willwood have even better kits, but you're looking at 2-5× that price.
AcesandEights
Aces
So. Oregon
2022 Jeep Rubicon 2D, with extra guacamole
Per Stellantis:
Sport
Front: 330mm x 24mm
Caliper: 48mm (1.88")
Rear: 328mm x 12mm
Caliper: 45mm (1.77')
Rubicon/Sahara
Front: 330mm x 28mm
Caliper: 51mm (2")
Rear: 342mm x 14mm
Caliper: 48mm (1.88") (Sahara, Sahara 4xe, Rubicon, Rubicon 4xe)
Sahara 4xe/Extreme Recon
Front Caliper: 51mm (2")
Rear: 345mm x 22mm
Caliper: 51mm (2")
Rubicon 4xe/Rubicon 392
Rear: 350mm x 22mm
Caliper: 51mm (2")
I hope this helps and doesn't generate a bunch of questions.
AcesandEights
Aces
So. Oregon
Here it is cut/paste, haha.
Front Rotor size and type 12.9 x .94 (330 x 24) vented rotor — Sport 12.9 x 1.1 (330 x 28) vented rotor — Sahara and Rubicon models Caliper size and type 1.88 (48) twin-piston floating caliper — Sport 2 (51) twin-piston floating caliper — Sahara, Sahara 4xe, Rubicon and Rubicon 4xe Rear Rotor size and type 12.9 x .47 (328 x 12) solid rotor — Sport 13.4 x .55 (342 x 14) solid rotor — Sahara and Rubicon 13.6 x .86 (345 x 22) vented rotor — Sahara 4xe, Xtreme Recon Pkg 14 x .86 (350 x 22) vented rotor — Rubicon 4xe, Rubicon 392 Caliper size and type 1.77 (45) single-piston floating caliper — Sport 1.88 (48) single-piston floating caliper — Sahara and Rubicon 2 (51) single-piston floating calipers — Sahara 4xe, Rubicon 4xe, Rubicon 392, Xtreme Recon Pkg
Rodeoflyer
Bert
Conifer, Colorado
Hmmm why would the 4XE use the same brakes as the 392? Is it that much heavier?
I've been satisfied with the Rubi brakes, even on 37'' tires. I swapped the factory fluid with Motul DOT 5.1 and that greatly increased pedal feel/firmness.
I'll be upgrading to these when the factory wears out.
TOWING, OFF-ROAD, HAULING UPGRADE
Z36 TRUCK & TOW BRAKE UPGRADE KIT
Jeep Wrangler JL Heavy-Duty brakes vs Rubicon brakes {filename}
FITS YOUR 2020 JEEP WRANGLER
Part No. K7938-36
AcesandEights
Aces
So. Oregon
Yes, that's exactly why, it's heavier. It's the heaviest configuration, heavier than the 392.
Edited to add: Stellantis lists the 4xe as 5,100 lbs in the Sahara and 5,222 lbs in the Rubicon. The 392 curb weight is listed as 5,098.
blnewt
New Mexico
Just ask @cosine he knows!
