what part? The clockspring? They should try repairing the end connections if it is going to take that long.2500 miles, 2021 JLUR, my heated wheel stopped working last week. Dealer called me today and said something is wrong with the wiring harness in the wheel and they have to order the parts. When will the parts be in? April. Yes, April. Super.
I think thatās the case where you should definitely replace the wiring harness, I donāt know how well Iād trust a patch job on such critical parts.Not on my Rubicon but on 2014 Ram the heated steering wheel would stay on for a second and shut off indicating a short. Dealer quoted me $400 for a new clock spring. Tackled the project myself and upon removal of the horn I could see one of the wires leading up the clockspring had been rubbing and the insulation was grounding with metal. Reposition the harness and insulated the wire, fixed the problem and returned the replacement clockspring Inhad purchased. Might be worth removing your airbag and inspecting all the wires and making sure the pins are all seated in the wiring harness.
Just got back from picking it up. Invoice says they ordered a new steering wheel, Module, and wiring harness. Said the SCCM connector and wheel connector melted.what part? The clockspring? They should try repairing the end connections if it is going to take that long.
oo boy thatās a bad one. Bad connections make for some hot terminals. Glad they are getting it fixed though.Just got back from picking it up. Invoice says they ordered a new steering wheel, Module, and wiring harness. Said the SCCM connector and wheel connector melted.
glady8or, did you get yours fixed?I got in my 2020 Gladiator this morning with the same problem! Turn on the steering wheel and it stays on for 2-3 seconds and then shuts off.
Here's some data on the heated steering wheel.Hello,
Just recently had my heated steering not stay on after turning it on. My jeep is out of warranty, so I would like to fix it on my own.
Anyone know what it could be? I see there are multiple other threads on it, but the only answer I found was to take it to a dealership.
Thanks
We can certainly dig in on this further with you, dmorton. Please send us a private message with some more details to get started.Just as an update, my jeep went in to replace the steering wheel on March 23rd. The dealer told me that Jeep sent the wrong part number. Put the old wheel back on and said they would reorder. I just called the dealer today (May 3rd) and they still do not have the part. They said Jeep isnt sending out the part and to give it a little while longer. Anyway, I wonder if @JeepCares can help?
Experienced this this morning. Auto started Ramona because of the cold and the steering wheel heater would not stay on. Got to work and shut her off then restarted normal and it works like it should on normal startā¦???Hello,
Thanks
