Heat to rear seats
Moabed
Ed
Southeastern wisconsin
2020 sport s
Hi guys. Anyone know how to get heat to the rear seat? Nothing coming out of rear vents.
iamstillvince
Vince
Alberta, canada
2020 wrangler sport s
I haven't tested it yet as I noticed same thing but I drive a 2door with rear seat removed soon wasnt in a hurry. Think it's just because air doesn't make it, try putting air on dash setting and closing all the other vents. Think it just can't push air all the way back
Moabed
Ed
2020 sport s
Moabed
Ed
2020 sport s
Great idea. It seams to only work when set to dash only. Actually blows heat with dash vents open and fan on high. Thanks
Cuyose
Shawn
Piedmont, SD
2020 Jeep Wrangler Rubicon
Data Analyst
Yeah there are no floor heat vents to rear, you need to manually set climate to airvents and turn up fan, close up as many front vents as you can. Auto will never warm up rear passengers quickly. It would be nice for an aftermarket solution for rear heated seats for sure.
Moabed
Ed
2020 sport s
I is nice to actually get a substantial amount of heat out of those rear vents even though it’s not an ideal situation. It’s better than nothing. Thanks for your input.
Oldbear
Dwayne
Bowling Green, Ky
16 Ram 1500 Ecodiesel; 20 JL Sport S 2 door
I dunno if they still make them, but there used to be small electric heaters made that ran off a 12v plug. Buddy used to have one in his old CJ5 to try and keep the driver warm what with the cold air coming in around the full cloth doors... might try one of those in the backseat.
Xcoaste
Ben
PA
2021 JLUR - Past - '13 JKU, '97 TJ, '93 YJ
I can confirm that when on auto climate, it hardly does anything at all to the rear seats. Like stated, you must go to manual mode and select the dash or straight at you option. It is disappointing though considering how well the Jeep heats the front passengers!
DavidArmen
Los Angeles, CA
2021 JLUR
My 2021 JL (and I believe all JLs) does have floor vents for the rear. There is one under each front seat blowing air towards the feet of the back seat passengers.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Yeah there are no floor heat vents to rear,...
Floor vents for the rear passengers are indeed present.
Jeep Wrangler JL Heat to rear seats JLU Floor vents
They're sold on Amazon and at Harbor Freight, and are far too weak to serve as a proxy for a car's regular heater. They pull 16 amps (enough to pop fuses) while 200 watts of barely warm air exit from a postage-stamp size opening. Avoid.
Moabed
Ed
2020 sport s
Thanks for all the input guys. I am happy just getting heat from the rear vents.
