Headlights turn on when turning on intermittent wipers?
boontis
Calgary, AB Canada
2020 Wrangler Sahara Unlimited 2.0L
I tried searching but couldn't find anyone else posting this issue. When I'm driving in broad daylight, if I turn on the intermittent wipers my lights will turn on. Then when I turn off the wipers, the lights immediately turn off as well.
I've tested this over the span of a few days and it's happening regularly. Any ideas? (other than gremlins?:))
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Theres a setting in the instrument cluster that can enable/disable that feature
Or maybe it’s in the radio, I forget which one but it can be disabled.
gm920
Gary
San Diego County Mountains
2019 Jeep Wrangler JLUR Billet Silver
Aircraft Maintenance Technician (Retired)
From the 2019 Owners Manual Pg 573
MULTIMEDIA
Mirrors and Wipers
After pressing the “Mirrors and Wipers” button on the touchscreen, the following settings will be available:
Lights
After pressing the “Lights” button on the touchscreen, the following settings will be available:
Setting Name
Selectable Options
Headlights With Wipers — If Equipped
On
Off
rob58
Rob
Steinhatchee, Florida
2020 JLUR
Retired Chemical Engineer
MULTIMEDIA
Mirrors and Wipers
Lights
Setting Name
Selectable Options
On
Off
Many states require headlights on when using wipers.
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
I just checked mine. Go to settings on the stereo, select “headlights with wipers” and uncheck to box.
Mine is a Canadian model and not sure if the US models are different.
boontis
boontis
Calgary, AB Canada
Thanks for the quick responses! The thought that this was a feature not a bug didn't even cross my mind. Thanks for clearing this up!
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Necro bump, but does anyone know if the "headlights on with wipers" feature works on any setting or just on the 'auto' headlight settings?
Was driving in a light drizzle this morning with just my parking lights on and "headlights on with wipers" setting enabled on the uConnect. Pulled into the garage with the wipers still on the lowest setting and noticed the headlights weren't on. Just trying to figure out why they weren't working as expected.
jludave
The Isle of Long
IT Manager
Headlight switch has to be set to "Auto".
  • Like
Reactions: AFD
AFD
Northeastern US
That's really dumb and should be noted in the owner's manual. Absolutely hate whoever programmed the JL headlights. Can't run "auto" since parking lights won't come on with DRL and now the "headlights with wipers" only working in "auto" mode.
Anyway, thanks for the clarification. Really do appreciate it!
ArcadeTracks
PJ
Pittsburgh, PA, USA
Fwiw, lights on in the rain is usually more to let other drivers/people see your vehicle, not to illuminate the road for you.
Babeinsap
Abe
North carolina
2021 JLU Sahara Altitude; 2001 TJ
It’s the law in several states…. Lights must be on when wipers are on
