Headlight high-beam splice point
bobholthaus
Bob
St. Louis, MO
2023 JKURD AEV JL370; 2014 GC Overland Diesel
Technology Integrator
I don’t know if you guys have considered using a Molex Perma-Seal heat shrink connector, but that’s what I use to keep things 100% waterproof. They make some units that are designed to bring two wires into one. I buy mine from Waytek Wire. You crimp them, and then heat shrink them, and you cannot pull them apart. If they are incorrect, you have to cut them off. I have been using these exclusively for almost 20 years now, and I have never had one leak or fail. I suggest buying the Molex crimper that has three different crimp sizes on it as well and is spring loaded. Well worth the money. Just a suggestion.
waytek
molex permanent seal crimper
KC HiLiTES
Rock Sponsor (Level 1)
Robert B.
Flagstaff, AZ
2020 Jeep JT, 1969 Wagoneer
Lighting Adventures Since 1970
I spent some time looking as well, and the Stedi UK harness adapter was the only one I found.
Probably not a big deal using a Posi-Tap, but I'd rather spend $40 and buy a pass-through versus risking corrosion potentially messing up my factory harness and LED headlamps if the splice (or Posi-Tap) isn't 100% waterproofed just right, especially in that location. The extra $60 for S&H is insane, though.
Would be a good project for @Baja Designs , @KC HiLiTES or @Diode Dynamics for their JL & JT customers that would like a safe/simple and easily reversible plug-and-play solution to control their off-road lighting via highbeam.
I'll send a request in to our engineering team. Thanks for the recommendation.
autotragic
the cornbelt
'21 JLR 6MT
I just want to say I'm interested as well. I personally have a strict "no splicing factory wiring" rule.
I'd rather go without before cutting into factory wiring. It's the same reason why I made sure to buy a Jeep with factory auxiliary switches too.
patternman
George
Phoenix AZ
2019 JLUS, 2014 & 2001 Indian
^^^ Anyone that would like a plug & play for this might want to like this post so KC HiLiTES can get an idea if they'd like to make this happen.
KC HiLiTES
Robert B.
Flagstaff, AZ
Jeep Wrangler JL Headlight high-beam splice point 1708615048067
If anyone is still interested, one of our engineers made up a few samples for testing.
Plug and play between factory harness and headlight.
Giving an output for low beam, high beam and parking light.
Has a butt connector on the ends to tie into a relay for control of another light.
We have 5 to giveaway to forum members in this thread who would want to test them. First come first serve.
Just send me a private message with...
- Name
- Mailing address
- Year/model of your jeep
- What headlights do you have
All we ask for in return is pictures/videos of your set up, how you are using it and some feedback. Our lights, other peoples lights, does not matter.
Grayhound
Michigan
Jlurd
- Name
- Mailing address
This is slick! Had I not already spliced my wires I’d be all over this!
bobholthaus
Bob
St. Louis, MO
Thank you for doing this; very cool. I already spliced mine as well, or I would be asking for one too! It is my opinion that you will sell a ton of these! Thanks guys.
MarkyMark
San Francisco, CA
19 Rubicon JLU 2.0t w/ eTorque & Moto Guzzi Griso
- Name
- Mailing address
Just sent you a PM! Hoping I’m one of the first 5. :). I’ve got everything wired up except the piggyback! Appreciate you doing this!!!!
KC HiLiTES
Robert B.
Flagstaff, AZ
You were the 1st. :)
We have 3 left to give out.
patternman
George
Phoenix AZ
- Name
- Mailing address
I sent a PM. Thanks for looking into this, I sure appreciate the effort. I hope lots of others see the benefit in what this opens up.
autotragic
the cornbelt
'21 JLR 6MT
- Name
- Mailing address
Sweet! That looks like a pretty slick setup.
autotragic
the cornbelt
'21 JLR 6MT
