Headlight Aiming Information
FatBoy01
NY
2014 Wrangler Sahara; 2001 Harley FatBoy; 2018 Wrangler Rubicon JL (Ordered)
Retired @ 55
  • Thread starter
  • Banned
  • #1
This info will come in handy after tall tire install and your headlights need re-aiming.
JL Headlight Adjustment:
Looking down at the adjuster's, you turn them clockwise (turn to the right) to go UP and counter clockwise (turn to the left) to go DOWN.
The video will show you where the headlight aiming adjustment screws are on the JL/JlU.
You will also learn grill removal and headlight assembly removal.
If you just want headlight aiming info, fast forward in video to 8:53 min. mark.
kkuntz01
Kevin
Mount Juliet, TN
2018 JLU Rubicon, 2014 Ram 2500 Crew Cab
This is good info everyone needs to check out and do on their rigs after lifting them, more so if you’ve got the LED package. If you don’t you’re going to be throwing light into the eyes of on coming drivers blinding them. You’ll also get sick of having drivers flash you thinking you have your high beams on. My wife deals with that all the time in her lifted Ram 2500.
BoisetheCat
Idaho
CR-V
Would i need to do this after slapping on 33's on my sport w/out lift?
FatBoy01
FatBoy01
NY
Retired @ 55
  • Thread starter
  • Banned
  • #4
Probably. Just find a flat area with a wall in front of it and go for it. Not hard to adjust.
Looking down at the adjuster's , you turn them clockwise (turn to the right) to go UP and counter clockwise (turn to the left) to go DOWN.
Here you can find in regard to aiming a vehicle's headlights:
http://www.jwspeaker.com/blog/how-to-aim-headlights-driving-beam-or-high-beam-headlights/
kkuntz01
Kevin
Mount Juliet, TN
I would say it’s not really necessary if all you’re changing are the tires. At most you’re maybe putting an 1”-1.5” in height under the Jeep depending on what kind you tires you started with. While that might seem like cause for needing to, remember you’re not changing the factory rake so any potential change to the where the headlights project light will be minimal at best. Where you run into problems is when you do a leveling or lift which changes the factory rake and ultimately changing where the projecting light and requiring you to re-aim them.
Like FatBoy said, it’s not all that hard, but then it’s also not that necessary in your situation.
JeepJL18
Jeep
United States of America
I will not be participating in this forum as of 8/31/2018. It's been a fun ride, but it's time to move on. Take care. - Dustin
offline
So glad I found this. Really annoyed by the flashing i get all the time :). No worries no more!
DirtRoad1981
Rich
High Desert
2018 wrangler JLU SPORT
Diesel Mechanic
Heck yea! Had a jacka££ swerve in my lane the other night and almost run me off the road. I kinda figured my headlights would rise a little with a 2.5 lift but not that much. I guess I was the jacka££ in the situation. But come swerving into my lane we’re gonna pass each other in a matter of seconds anyways
OldGuyNewJeep
Don
CT
My Rubicon is still bone stock (LED package) and I get flashed, constantly. I know I’m being passive aggressive, but I’ve taken to flashing back so they can see “it gets a whole lot brighter, bud!”
I’m going to check my aim, though it seems odd that’d be off from the factory.
WXman
Central Kentucky
2018 Wrangler Unlimited
6mm hex bit on a ratchet with an extension. Easy peasy. If you have a garage, the door will make a good backdrop to aim them against.
  • Like
Reactions: J0E
Rhinebeck01
Multiple places..
Yes, easy to adjust...
Hint..... Mark the adjuster with 2 dots of ink, before you make an adjustment. This way, you know where you started and can get back to the original adjustment.... back to square one should you want to.
OldGuyNewJeep
Don
CT
I get flashed every time I drive my Rubicon at night so last night I adjusted my headlights down 1.5 full turns. This morning...not a single flash. Finally some peace while driving.
How did you come up with 1.5 turns? By aiming, or just a W.A.G.? I need to do this, too.
  • Like
Reactions: J0E
eaglesjw
Elkhorn, NE
2018 JL Wrangler Unlimited Rubicon; 2014 Road King
Trial and error. I did 1 full turn and then went for a test drive. I got flashed once and still didn't like how the lights were hitting parked cars in the neighborhood so I went back and did another half turn. Haven't had any problems since. Not very technical but it seems to have worked.
OldGuyNewJeep
Don
CT
Marked my adjustment screws with white-out and backed them off 1.5 turns. Thank you for sharing and saving me the hassle of running my own experiment! I suppose if I get flashed, again, I'll make my dealer adjust them. I can't be bothered to find somewhere that's flat, that will let me pull right up to a wall, and that will then let me back up 25 feet.
eaglesjw
Elkhorn, NE
FYI...I have a Rubicon with stock tires and no lift. It might be a little different depending on your setup.
