has anyone resisted a throttle enhancer after trying?
imjester77
Frank
2020 JLU Eco Diesel; 2014 JKU Sahara
Fuel injection showed up in the Camaro and Mustang in the 80s.
First generation of each of those cars was in the 60s. They were up to the 4th generation each by 93/94.
True story but they were throttle body injected until the 90's and thus the reason I said 1st Gen throttle bodies. Not vehicle, yes the 90s were 4th and 5th generation. But for direct port injection and full drive by wire throttle bodies were in 94.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
The Camaro got tuned port injection from 1985 through 1992. The Ford HO was port injection in 1986 as well.
imjester77
Frank
The Camaro got tuned port injection from 1985 through 1992. The Ford HO was port injection in the 80s as well.
Hmmm... I'm googling now... it's been years since I've been under fox body.
imjester77
Frank
You are correct and I stand corrected..87 was the first direct port injection Mustang. And 89/90 for the Camaro. I'm getting old!
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
TPI showed up in the Corvette and Camaro in 1985. Ford HO got port injection in 1986. That was right about the time I was old enough to get my license so I remember it well.
Second generation GM port fuel injection showed up in 1992 in the Corvette and in 1993 in the Camaro. Ford went to the 4.6 modular motor and injection in 1995 or so. I was always more of a GM fan and remember them better.
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
Do they come with preset modes or "tunes"? I'm all for a better running diesel and care less about the speed and 0-60, but I'm not about to go down the road of guessing settings such as when you do a bunch of mods to a turbo'd car and need the ECU remapped after this and that, including a dyno tune etc. Does it let the diesel be happier as a diesel basically? And what does each module do, Banks vs Derringer. I'm good with pulling it for any factory warranty things within the first 36k or extended time, just reset to OEM specs and have the work done, then restore?
Does the banks one with i dash super gauge let u see regents and other info or is that just the tuner thing?
Banks is the company, Derringer is their performance booster, PedalMonster is their throttle improvement module. The have preset levels you can select, you don’t get to tweak anything. The iDash can monitor everything on its own, just plugs into the ODB, you can change what you monitor to anything on their list. None of what Banks offers for the 3.0 is a true tuner that modifies the ECU, they intercept signals and alter thresholds. It is advised you pull the derringer and pedalmonster when going in to service.
Omotose
Frank
AZ Desert
2021 Rubicon Unlimited Extreme Recon
I ran a Pedal Commander on my 2017 Ram with the 6.4 hemi for about 8 months. Then it lost its mind and locked into limp mode. I tore it out and gave up on it.
00 Trans Ram
New Orleans
2020 JLU Sport
Just watch the first minute or so of the video and you will see what they all do...granted this is an advertisement against knockoffs so you don't need to watch the whole thing unless it intrigues you like it did me.
So, I guess I was right . . . and wrong!
It doesn't reduce "input lag". If you slow the video down and measure it to the millisecond, there is still the same amount of input lag (8 frames of that video, regardless of if the unit is off, green/4 or red/9).
However, I see that there is a definite lag difference between WOT with the unit on and off.
I might have to get one of these and try it out.
rickinAZ
rickinAZ
Phoenix
Throttle enhancers are not ideal for a naturally aspirated engine. Before it malfunctioned did it feel like it worked? FWIW, I'm only advocating for the Ecodiesel application.
Terpsmandan
Penn Yan
Not sure if you're joking, but If you'd ever driven a throttle enhancer equipped Ecodiesel, you wouldn't ask. That said, it's a logical question, but, no, you can't get the same effect by pushing the accelerator harder. [unless you have the consistent precision of a robot. Wait...that's basically what a throttle enhancer is. :)]
This is one of those products that must be experienced. I asked my original question because it's hard to believe that an owner could try one and be anything but delighted.
It literally transforms the driving experience. I'm just trying to share the wealth.
Now you got me thinking. So what dose it do on a diesel? I understand what it's doing with a gas engine and changing the speed the throttle plate opens. Correct me if I am wrong, but air doesn't get throttled in a diesel. if so, what are you changing with one of these?
TurboTime
Jay
Los Angeles
2020 JL 3.0L
I recently traded my 2020 GC North Edition for a 2022 Ram 4x4 Truck. The GC North package had a factory ‘Sport’ button on the dash that acted like a ‘Pedal Commander’ and made the engine RPM/throttle response 3X better. It was sweet. I recently ordered a diesel Wrangler and will definitely be adding a Pedal Commander to it.
It may be worth taking a close look at the Banks PedalMonster. It's the only one with Reverse Safety. It puts you back to stock in reverse gear.
zouch
Berkeley, CA
XJ, JLUWD
wouldn't that be 60 months/100,000 miles ? (at least, that's what it says for my Powertrain Warranty.)
[snip] I'm good with pulling it for any factory warranty things within the first 36k or extended time, just reset to OEM specs and have the work done, then restore?
