has anyone cut in real hood vents?
sourdough
left coast
JL
I recently got rid of my Rubicon hood and am looking for some real side vents to cut into a non-Rubicon hood. I just want side vents that let out some heat. So far I found these for a JK and not sure they will fit.
https://www.z8offroad.com/collectio...7-jeep-wrangler-jk-jku-unlimited-rubicon-hood
and these bigger units with a Rubicon script in them...
https://overtread.com/product/hood-grotto-jeep-wrangler-jl-gladiator-18-20/
I am not sure they can be purchased separately but I'm trying to find out.
Mr. Curti
Justin Curti
Tulare, California
2020 JL EcoDiesel
Dairy Farmer
sourdough
sourdough
left coast
JL
mjaga
Illinois
2021 JLUR Sting Grey
I've come across some videos online. Some say it helps heat dissipate, some say don't do it as it induces hood rattle. I'm undecided if I'll do anything to them yet.
sourdough
sourdough
left coast
JL
I have yet to find "cut in vents" that I like. I'm now looking into raising the rear hinge side of the hood. kind of like this but not this extreme...
Jeep Wrangler JL has anyone cut in real hood vents? vw raised hood
Being a low pressure area on a Wrangler seems like heat would easily be vented out.
sourdough
sourdough
left coast
JL
I made a couple of hinge extensions today. 3-1/4" x 2-1/2" 3/16 alum. plate with 4-5/8"holes. Raised the back of the hood 1-1/2" for hot air venting. I found this is the minimum rise I could do with a plate extension. I am now contemplating modifying the hinge by just extending it. That requires adding to the length by welding. By doing so I can get a lesser rise but with the hinge alteration it would be hard to reverse to original.
Jeep Wrangler JL has anyone cut in real hood vents? jl hood vented 1
Jeep Wrangler JL has anyone cut in real hood vents? JL hood vented 2
Note: these hex head bolts did not work due to clearance issues as noted in post #10
Jeep Wrangler JL has anyone cut in real hood vents? jl hood hinge extension 1
Jeep Wrangler JL has anyone cut in real hood vents? jl hood hinge extention 2
bgrex
Bill
NJ
JLU Sahara Altitude - Sting Gray
Curious what’s driving this mod...Were you having issues with your Jeep overheating? Or is this a ‘just-in-case’ prep? Or a cosmetic preference, etc?
sourdough
sourdough
left coast
JL
Why? Engine temperture spikes during short shut downs on the trail. So I've been playing around with couple small mods. I just recently installed the JT grill screen with larger mesh and have a low mount winch for better air flow also.
update 11/11: after many miles of hot trails, I have not had the temperature rise spikes as before.
sourdough
sourdough
left coast
JL
Update: I also removed the hood liner and plastic horse shoe engine cover. On the aluminum extension plates, I replaced the hex head bolts with carriage bolts (button head on cowl side) to clear the plastic cowl vent.
Jeep Wrangler JL has anyone cut in real hood vents? hood hinge extension a
This hood hinge extension for venting has proven to work very well. I was concerned that rain might be an issue but we just had record rain last week and no water intrusion issues.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
@wibornz did this, and used a specific material that allows heat to escape without also letting cold rain water to flood over the hot motor.
N875ED
Lebanon, OH
2021 JLU 80th Anniversary
You’ll want the fan running to move the hot air from the engine out the rear gap. Some kind of manual fan-override switch?
Aonar
N.W. Iowa
2012 Rubi and Snazzy 2021 JLURD
Any idea how much these 2 changes helped with heat dissipation? How about increase in sound levels from under the hood? Have a JLURD on the way and will be on trails in CO in July. Sound not such a big deal to my old ears though. I wonder if the hood would get too hot without the liner? Is it there for metal/paint protection or just sound deadening? I am tempted to try these 2 things as soon as I get mine.
calemasters
Allen
Springfield, Mo.
2021 Rubicon Unlimited, & Escalade
Retired Mechanical Engineer
There are many videos on youtube. Since the hood is aluminum, you will want aluminum hood vents. Right?
