Depends how you raise the top. If you run the straps front to back through the rear window then you have to have the rear window open. If you use Topsy hooks or another lifting method that doesn't run thru the rear of the top you should be able to lift with it closed. I use Topsy hooks on my top with a Harken hoist and store the top closed.
