Hardtop Cart / Holder DIY
theryko
Seattle
2018 JLU Sahara
Thanks for the the specs! Gave er a run and it turned out pretty good. Carpeting took the longest.
Now to put the hard top on for the test fit.
JLUandCJ-7
Tim
Charleston, SC
2020 Sahara w/mods
Lots of projects this weekend!
Here is how to build your own hardtop cart and save a $150.
2 2x4 cut to 29"
2 2x4 cut to 60"
1 1x2 cut to 60"
4 2x4 cut to 15"
4 caster wheels - if your garage is at a slant get locking casters
25 2.5" screws
Staple gun
Carpeting of your choice...
Total cost was $20 at home depot...$13 at Walmart for 2 yards of soft material...$14 at Lowes because my staple gun broke..
I carpeted the whole thing just because. Also, you will see I have my hard top set behind the front 2x4 but you can set it on top. I felt it was more secure that way.
I started by carpeting the 5 main pieces; the 2x4's and the 1x2.
Once those were carpeted I placed the 29" pieces under the 60" boards and clamped each corner going one corner at a time. Drilled pilot holes and put 4 screws in each corner.
Once the frame was built, I put the 1x2 6" back from the front board. That way there was space for the wiper. This board will hold the wiper off the ground if you do not secure the window to the hard top.
I then pilot holes and drilled/screwed the first 15" board 8" from the edge. Then screwed the 2nd 15" board to the top of that. Once they were both screwed down I carpeted them.
I then flipped it over and put the caster wheels on. I got wheels that spun 360*; if you do the same make sure there is room for them to spin.
Attached are the results!
**the blue tape was used to hold the window while we were lifting on to the cart..it was then removed.
Very happy I found your post. Will save a bunch of money vs buying one. Assembly starts tomorrow.
Texas_Yote
Texas_Yote
Kris
Prosper
www.instagram.com
18 JLUR Granite, 15 JKS 2DR, F80 M3
Slang 1's & 0's
Awesome, I am taking the hard top off tomorrow and this will be it’s 3rd year in use. Still going strong!
Renhilio
Tony
Northern VA
2021 JLU Rubicon
This is an old post, but wanted to share my results. I have a short garage that eliminates using a hoist to store the hard top. Boy am I glad I found this thread! Assembled and used the cart two weekends ago and it works like a charm. A big thanks to this community for always providing detailed information on anything and everything. One thing I plan to do is plug a couple of eye hooks into the wall and snugging the top against the wall with a strap to prevent any accidental movements. The cart is on locking casters but I like a little more reassurance. Beyond that I’d like to potentially wrap it with something, maybe plastic cling wrap or something?
JLUandCJ-7
Tim
Charleston, SC
2020 Sahara w/mods
Finally got my hardtop off and the diy cart in use! Good to have while I'm getting my power hoist installed.
Smart Stop Start
