Hard wire dashcam or radar detector in jeep with ACC
raj21747
raj
Palm Desert, California
R. Enfield500, Suzuki M109, 392XR, 1999 TJ
Hello everyone, does anyone have any experience in hardwiring radar detector in jeep with ACC? thanks.
zgrw
2021 JLUR
I recently wired a dash cam, but I have auxiliary switches, and carried the dashcam's cable to the passenger side and wired it to the cables there.
raj21747
raj
Thanks. Would you have a write-up of this by any chance?
rent
Roaming Around
2021 JLUR XR
I wrote up something quick here. My cam was installed to the driver side of the ACC box. The cables were easily passed thru the box along the top of the window frame with a fish tape (I used a long 1/4" socket extension just happen to be around).
raj21747
raj
Thanks. That was helpful.
Multiple places..
@raj21747
Does your JL have Aux switches?
raj21747
raj
@raj21747
It does and that's what I'm thinking of tapping into. All the videos I've seen are of the access from the hood but I believe there is an access at the passenger foot area as well. Would you happen to have some pics or link to video where the access it at passenger foot area for interior accessories?
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
I went a much easier route, I tapped into the wiring for the rearview mirror and installed a USB port. Then plugged the camera into the USB port. Mind you I took down the rearview mirror as I can't see out of it anyways with the big tire on the back.
Jeep Wrangler JL Hard wire dashcam or radar detector in jeep with ACC 1636476063215
Multiple places..
@raj21747
Read through this whole thread for the info you need in regard to the Aux bundle found in the passenger side foot well.
https://www.jlwranglerforums.com/fo...switches-configuration-installation-diy.1477/
raj21747
raj
rent
Roaming Around
2021 JLUR XR
Typically it's right behind the glove box (remove it). It's hard to spot at first, just a bundle of wires taped up (in black cloth-like tape) in a bundle, with the end folded onto itself.
Il Commandante
Dirk
Northern Germany
2021 JLUR 2.0
What type of dash cam do you use? Thank you!
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Yep, just tapped into #5 in the aux harness. It is a 10 amp ignition switched hot that doesn't waste one of your aux buttons. Works great, you can run the wire up the a pillar and tuck the wires around the upper frame of the windshield in order to hide all your wiring.
