viper88
I notice garages are getting smaller and smaller in some cities. That thing probably would not fit in some modern garages.I'm glad that someone else has a garage that's tight due to Mopar muscle!
Sweet ride! My very first car wash a '70 Challenger with a 383. I bought it as a project car, had it towed to the house and worked on it for 2 years before I even had my license. That was 1979 and I wish I still had that car now.I'm glad that someone else has a garage that's tight due to Mopar muscle!
How does it work with sunshade on?I'm really liking the Top Lift Pro. So easy for one person, and even works with a sunshade on.
For storage, it doesn't take up much space even in my small garage!
I just have to disconnect 2 straps on each side of the shade (very back of shade). Then the part of the tool that rest against the underside of the hardtop doesn't have any interference.How does it work with sunshade on?
If you could that’ll be great! I’m trying to figure out wether I should get the Jtop or the HotHead. Thanks in advance.I just have to disconnect 2 straps on each side of the shade (very back of shade). Then the part of the tool that rest against the underside of the hardtop doesn't have any interference.
I have the JTopsUSA Shade. Let me know if you want to see any pics and I'll take a couple. Take care!
When I had my JK I had an idea to build a table similar to this, but wide enough to back the Jeep into. Then I could push the back up a few inches and slide a 2x6 under, supported on the table, then do the same thing on the front and drive out. You could put casters or wheels on it if you want, so it could be moved after. The boards would have cheap carpet stapled to one side so the bottom edge of the hardtop wouldn’t get scratched.I built this. Back the Jeep right up to it, lift HT and push back just enough to get the rear lip of HT onto the "table". Only need a couple of inches. Then just slide back into place until its off the Jeep and fully on table. One man job for just about any able bodied adult male. Im 47, 5'8", with average strength, and its not bad at all.
Also, I leave it outside out by the shed. If you want to store the top indoors, Im sure you could use this in your garage too. I just dont have room so the top lives outside.
Sorry for the delay with pics. You just take the back two straps off each side of the JTops Sunshade before you move the TLP Hardtop Removal Tool under the hardtop. Hopefully you can see it in the pictures below. Then just snap them back on after removing the top.If you could that’ll be great! I’m trying to figure out wether I should get the Jtop or the HotHead. Thanks in advance.
Thank you so much. I will order soon.Sorry for the delay with pics. You just take the back two straps off each side of the JTops Sunshade before you move the TLP Hardtop Removal Tool under the hardtop. Hopefully you can see it in the pictures below. Then just snap them back on after removing the top.
