Bobby Boucher
- Bob
- Mar 31, 2019
- Central VA
- 2019 Wrangler 2-Door JL
With the new bolt pattern on the windshield pillar, I was unable to use my Rugged Radio antenna mount from the JK on the new JL.
Since I'm not a big fan of mounting the antenna on the tailgate, I wanted to keep the mount near the front of the vehicle.
However, I found that the standard NMO right-angle antenna bracket did not provide enough clearance from the body for the base of the antenna.
So, off to the the metal fabrication shop. A nice piece of stainless was cut to extend the mount away from the body.
The antenna and power cable are routed through the firewall near the brake booster.
I have a Yaesu FT-8900R unit under the passenger seat and the control head is mounted with Scotch clear double-side tape in front of the shift selector. The speaker is mounted to the front edge of the console using the same tape.
