HALO lights in Europe/Italy
fratnike
Enrico
Trieste - Italy
JLU Rubicon 2.0l turbo (ita version)
Dear all,
I have seen many beautiful images of your JLs in which you have active DRL + HALO.
I have bought a JLU Rubicon 2.0l turbo (no e-power available for Italy) with also the LED lights option but the ring inside the main headlights seems not working.
Do you have any idea if this feature is working only for the US market?
Thank you in advance if you have any information and many greetings from the north-east of Italy
Enrico
Obiwanpat
France
JLU Rubicon
hello everybody, I have the same trouble on my Wrangler JL Rubicon 2.2 diesel
I have bought the tazer mini to activate them, instead of that it stopped my fender DRL and I can't turn them ON anymore.. :((
help
JL.FR
Casa
France (Europe)
JLU RUBICON 2.0 Turbo MOJITO
Dear all,
Enrico
You do not like us in France and all over Europe I think ... I looked at the drawings and I dismounted a lighthouse and unfortunately there are only three pins on the connector on headlamp EU, low beam, hight beam, and ground ... nothing else on US model there are 4 pins , the last one is for Halo ...
UKJeep2018
Luke
United Kingdom
Jeep JL Wrangler Sahara
I’d like to know if the Halo Daytime running lights can be switched on. I noticed with tazer JL you can switch DRL’s region. If anyone with a European spec wrangler has the tazer maybe they can test it?
I suspect Jeep disabled it because of rules regarding daytime running lights in Europe
AndysJL
Andy
Darmstadt
Wrangler JL 2.2 Sahara MY18
did you manage to get that male connector out of the lamp case?? I can only move it a few mm left and right but then it is blocked.
Just thinking of looking inside to see if there is a chance to reach the halo .. or at least to see if there is one inside at all..
BTW part no. is 55112880AD
Howi
Cheshire, UK
Jeep Wrangler JL 2019
Any more news on this? , would be a great mod to do !
mbinzayed
Mohammad
United Arab Emirates-Dubai
Hi,
I am facing the same issue with my Sahara JL 2019 bought in the United Arab EMIRATES (Dubai), I guess we are following European standard in terms of specs.
From the look of the headlight, it seems the Halo ring is there but disabled, I am not sure if the headlight is disabled by the software or hardware (4th missing wire). Anybody have any information if Tazer JL will help or wire modification is required.
I am in love with Hale light look it is differently better.
UKJeep2018
Luke
United Kingdom
Well I just went and switched up my LED’s for the USA ones to get the halo. I powered the halo by using a fuse piggy back thing on the cigarette lighter fuse. I wasn’t sure if our BCM would even power the halo so I chose the simple route. Looks awesome.
Also I believe the EU LED’s come with some kind of auto levelling device for the lights. I was able to successfully migrate the devices to the USA ones, replacing the manual ones they come with.
hidprojectors
Tom
Buffalo, NY
2007 JKU
We can modify your stock headlights to add a new halo that is either switchback (white Daytime Running Light and amber Turn Signal) or Color changing.
We are in the USA though so you'd need to either purchase a new set from us or mail your stock lights in to us to complete the work. You can see our options here: https://www.hidprojectors.com/collections/wrangler-jl-2018
Tadek6
Nick
Uk
JL 2019 4dr Rubicon / 2015 Jeep GC SRT
Jeep Wrangler JL HALO lights in Europe/Italy OEM JL HIDprojectors 2
Hi Luke,
I want to do the same if possible. Where did you source the USA ones from? Was it a kit or just a wiring loom into the existing headlights?
Thanks
Nick
Sarathzzz
Sarath
Uae
Jl
H
Hi,
Hey
Found any solution?
Let me know
Thanks
RockinCoder
UK
Jeep Wrangler JL Sahara 2019
Just thought I'd add something to this from my own experience. I bought a JL Sahara 2019 with factory fitted LED pack. It looks like it has the halo factory fitted but not enabled from looking at the front of the headlamps, they have the tell tale ring. But on checking the LED headlamps, they do not have the halo part fitted inside and pin 5 is missing with only the 3 wires going to each headlamp instead of 4 required for halo's.
I also found out that if you do get halo headlights for European JL's you cannot use the Tazer JL to enable them as the driver outputs from the body module are actually used to drive the side repeater/indicators on the side mirrors (which US jeeps do not have), which is mentioned on the zautomotive.com website at the bottom of the Tazer JL description. So you would need to power them from the cigarette fuse as UKJeep2018 said earlier.
Hope that helps someone 🙂
Sarathzzz
Sarath
Uae
Jl
Why not wire the halos to the fender leds ?
RockinCoder
UK
Sorry Sarathzzz, just saw your question, I think the fender LEDs are powered from the body module on their own circuit. These outputs were probably not designed to power more than the fender LEDs(usually MOSFETs are used to switch them rather than relays inside the body module). Adding the halo LEDs could overload the circuit and damage your body module. I personally would drive them as UKJeep2018 mentioned, via the cigarette fuse output.
