I asked this on a thread on FB and the original poster confirmed that you will NOT be able to order the dual top group and dual door group on the same build. It is either or for the exact reason there is not enough space for the soft top in the back and the doors.This was my thinking.
Also, if I got the dual top (as I did with my order for my 19) and wanted dual doors....
how am I exactly taking all this home!? And exactly to your original point (cause really youād assume it comes with your order itās delivered like this from factory I assume, or maybe itās what you stated, which I think would be a paint match issue) how is this delivered to the customer properly?
curious to know why the answer is on this
I don't have bubbles around my door hinges. Even JK mopar half doors were aluminium.I wonder if they will have the same ābubbles around door hingeā feature the full doors have. Personally wouldnāt waste my money on half doors from factory - unless good old steel and not aluminum.
Gotcha....thanks for the info.I asked this on a thread on FB and the original poster confirmed that you will NOT be able to order the dual top group and dual door group on the same build. It is either or for the exact reason there is not enough space for the soft top in the back and the doors.
They will probably get there. You could order JK that waycan you JUST order with half doors only or do you need to take both?
curious to know what the answer is on this.
You don't have them now, but you have a good chance of having them. A large percentage of Jeeps get them. Usually start showing up when the Jeep is a year and a half to two years old.I don't have bubbles around my door hinges. Even JK mopar half door were aluminium.
It's more open than lowering the window but you can keep the uppers in the back for when you need themI know that people love half doors. Having never had them, I guess that I just donāt get it:
what is the difference between a āhalf doorā and a āregular door with the window rolled downā???
Iām serious. Iām a newbie and I donāt āget itā.....
That may be BullMoose1776's reason for half doors. For me, when I'm off-road and I need to precisely position my front tires so that I can avoid a hole, avoid a rock or climb a ledge, I find it much easier to lean out and see exactly where my tires are going when I have half doors (or no doors) than when I have full doors.Youāre pulling my leg, right?
I cannot imagine they wouldn't be. That would be crazy if they weren't.For $4k I hope the locks on both set of doors are keyed alike
