Had my first death wobble.
MT1
Michael
New York
Nissan Altima
2020 Rubicon, AEV 2.5” lift, Steersmarts front track bar, drag link and tie rod, new steel steering box, 38,000 miles.
I was driving home yesterday on a two lane highway with my wife and kids. There were steel drain gates on both the left lane and the right lane. I was going about 60-65. I went over one of the drain gates and felt a slight shift (more than normally expected). As soon as I hit the next one I immediately went into a death wobble. I’ve never experienced this before. My instant reaction Was I blew a tire out. Very, very quickly I realized what was happening as it seemed to increase in intensity rapidly. As I was slowing down gradually, trying to control the wheel so I don’t jump lanes (it was a packed highway), checking all my mirrors making sure no one was going to hit me, all I kept telling the family was , “Don’t worry. It’s okay.”
As I hit around 5-10 mph, it finally stopped and I kept going.
My wife was cool during it. My daughter almost freaked but held it together. And the best part was, my 8 year old son was sleeping and obviously woke up. After it was over, he started cracking up. He thought it was awesome. If I could of done it again, he would of been all for it:)
Creeker
Jim
Hickory, NC
CJ-7, 2020 JLR
Glad you are OK.
With the SteerSmart system, the bolt for stabilizer shock that goes to the bar came loose a couple of times. Last time, I used a lot more blue Loctite, and the bolt has not come loose.
IMHO, the single bolt to hold the stabilizer to the bar needs to have some kind of mechanism to keep it from vibrating loose (e.g., safety wire, mechanical lock, etc.)
Bswen
Atlanta
2018 JL Sahara
Death wobble nooo fun in traffic. In no traffic it still sucks too. Doubt its the wheel balance weight. The dealer will replace your steering stabilizer with another useless one that masks the issue for a while. Also trackbar could be replaced by factory and wont solve the issue permanently. Local shop in Atlanta has stated they install a steering BOX stabilizer bracket and that it permanently solves the issue for their customers.
Last time it happened to me the dealership put a Fox steering stabilizer on mine and no issues yet, but I still cringe when I run over something that offets between the front tires. Ive had 7 or 8 steering stabilizers and a couple trackbars between my 18 & 19 JL Saharas.
Dr. RGB
Ryan
Leesport, PA
www.readingecs.com
2020 JLW in HELLAYELLA, 2020 BMW R1250R 718 Option
Assistant Professor and Licensed Professional Counselor
That's the worst! My first and last DW was a track bar that was no longer torqued to spec.
MT1
Michael
New York
Nissan Altima
  • Thread starter
  • Thread Starter
  • #6
Checked all the bolts and greased the fittings. I did notice that the draglink Pittman joint did have a small grease leak. It still had grease in it but was obviously coming out from somewhere. When I pumped some grease in it, I could see it coming out from a puncture/slit that I can’t actually see.
never thought to check the stabilizer bolt. I’m running a fox ats, so it shouldn’t hopefully be the stabilizer itself. I’ll definitely have to check it’s on there tight.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Assuming everything in the steering and suspension systems is torqued to spec, it may be the ball joints. You're already beyond the mileage point that others have reported looseness in theirs.
Creeker
Jim
Hickory, NC
CJ-7, 2020 JLR
If you have the Synergy Sector shaft brace, check the large nut (Maybe 1 7/8" hex) that holds on assembly. Mine came loose. Used a bunch of red loctite and re-torqued to ~180 Ft-Lbs. So far, so good.
MT1
Michael
New York
Nissan Altima
  • Thread starter
  • Thread Starter
  • #9
I’ll definitely have to check out the ball joints. Probably going to have to wait until the weekend with all the snow coming to NY tomorrow.
MT1
Michael
New York
Nissan Altima
  • Thread starter
  • Thread Starter
  • #10
Glad you are OK.
And you are the winner. How the hell did I miss that the first time?! Thanks!
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
If you have run larger tires, do not be surprised if you need new ball joints with the amount of miles you have on your Jeep.
MT1
Michael
New York
Nissan Altima
  • Thread starter
  • Thread Starter
  • #12
Running 37’s. Just spoke to steersmarts and ordered the countersunk bolt I need for the stabilizer. Have to say, speaking to them through their chat system was great! Props! I agree, I think it’s time to order ball joints. Seems like most people recommend the Dynatracs.
MT1
Michael
New York
Nissan Altima
  • Thread starter
  • Thread Starter
  • #13
Am I right in looking at the dynatracs? They run $630 pretty much everywhere I look.
wibornz
Ted
lansing, Mi.
You mean these?
I was $613 delivered from Northridge4x4. I am putting them in either on Friday or early next week. I already installed a set last week on my buds 19 JLUR. He has 43,000+ miles and his OEM ball joints were shot. Only the boot was keeping them from slopping around. They should have been replaced probably 5000 or so miles ago. I suspect mine will be the same.
MichaelAnthony
Michael
Aliquippa, PA
2019 Wrangler Rubicon JLUR, 97 Centurion Dually 7.3, 97 Classy Chassis Dually 7.3, 2016 Ultra Classic CVO
would/could you post a picture of that bolt? I have a set up from Synergy and trying to get it to work with mine.
Smart Stop Start
