GROUPBUY for Sidetrack™ LED Lighting System for Jeep Wrangler JL
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
GROUPBUY IS FULL
To pre-order visit
https://www.oraclelights.com/products/sidetrack
GROUPBUY Information:
We are making the Groupbuy offer availble to a limit of 25 people.
Groupbuy discount can not be combined with any other offers. Any order received with a discount code will be rejected.
To order by phone call 1(800)407-5776.
ORACLElights
ORACLElights
Metairie, LA
Groupbuy is almost full so we will be closing the group buy tomorrow morning, last chance to put a deposit down!
JLSpartan
Roman
Michigan
18 JL Sport
Just found these on Facebook and pulled the trigger. I’ve been wanting something for the space these go in and these just seem to fit my build. Looking forward to it!
ORACLElights
ORACLElights
Metairie, LA
Ok, we did a quick write up for the installation guide so anyone "on the fence" can decide if they want to join the GB before it ends. The final instructional video will be a bit more detailed.
1) Begin by pulling back the inner fender liner by removing the (3) outer fasteners, unscrewing (2x) 8mm bolts and (1x) 10mm bolt. Video: vimeo.com/385284993
2) Now clean the painted surface of the fender with the included Isopropyl alcohol pads to remove any wax or residue that may inhibit tape bonding.
3) Using a plastic panel tool, wedge the fender vent open to route your cables. Notice the back of the light panel has a channel for the wires to exit without being pinched.
4) Once positioned peel away the red tape backing and begin to apply the panel to the fender. The outline of the panel matches the outline of the fender indentation, use this as a guide.
Wiring Detail:
5) Now connect the turn signal (White/ Green Wire) with T-Tap and plug in the yellow wire from the Sidetrack Light. The cable is located in the fender directly above where they wires enter through the fender vent. (You can unplug for easier access but remember to plug back in).
6) Route the White wire through the firewall. On the passenger side route through the main wiring harness behind the fuse box. On the Driver side route though this grommet which is visible with the wheel liner removed (see photo).
7) Now connect the Courtesy Light (Yellow/ Brown Wire) with T-Tap and plug in the White wire from the Sidetrack Light. The cable is located in the footwell and is plugged into the LED Courtesy light (You can unplug for easier access but remember to plug back in).
8) Repeat steps on the Passenger Side and Enjoy!
Jeepileptic
Charlotte, NC
2019 JLU Rubicon, 2016 Fisher-Price Jeep Frozen Edition
GROUPBUY IS FULL
To pre-order visit
DANGIT!!! I just saw this. Day late and a dollar … whatever the stupid saying is...
ORACLElights
ORACLElights
Metairie, LA
Dang! :crying: We'll post when it fully launches, and you can still get our regular forum discount on yours.
thecritter
Rusty
East Texas
2018 Crystal Granite JlU Rubicon
Missed it as well any ETA on release?
ORACLElights
ORACLElights
Metairie, LA
nerubi
Nebraska
2019 JLR, 2020 VW Tiguan
Here's an idea - convince Jeep to include these on all Wranglers coming out of the factory buying from you and offer to the owners prior to factory inclusion to buy at the volume discount price of say $120.
Dave928
Washington
2020 JLU Rubicon, 03 Silverado, 88 Porsche 928 S4
Aircraft Tech
you kidding? they'd want an extra $600 out of you.
ORACLElights
ORACLElights
Metairie, LA
skyallen
Jax
Louisville
JL Wrangler Unlimited Sahara
200$ is a lot for this type of light.
ORACLElights
ORACLElights
Metairie, LA
Not $200 with a coupon ;) There are other cheaper options out there that simply won't stack up in quality to Oracle Lighting that some choose to explore...whatever works for your needs and budget.
