AtlasRearden
- Oct 25, 2021
- Laguna Beach, CA
- 2019 Jeep Wrangler Unlimited Rubicon
Fair enough--the video is still helpful in places. It's just important to pay attention to Grimm's installation guide.We were the first to install that kit when they first came out and have learned a lot since that first install.
Here's where I ended up on trimming. I hope I didn't go so far that there's so little metal left that it doesn't do any good. I even ended up taking the grinder to my brand new $2,000 winch to make it fit. It seemed like that portion of the winch housing was decorative, so it gave me just a tad more clearance to make it fit. It still touches the brackets, but at least I got the winch to slide forward enough to mount it through the holes in the winch place.The amount of trimming really depends on the Jeep. Most only require a little, like we showed in the video and that is for the brackets to just clear the winch perfectly. Every now and then we'll see one that need more trimming. We've also started trimming more of the bracket out than shown in the video, just to give a little more room.
The angle of the pictures are a little misleading, since it makes it look like the bottom holes in the bumper brackets are well under the winch--they are not.
It actually came with 6 bolts, so all three bolts on both sides of the winch plate seem to get replaced.For the bolts, you must be talking about the lower two bolts through the side? When we installed it, they hadn't started adding the two longer side bolts into the kit yet, so we reused the OE bolts.
I reach out to Grimm, and their only advice was to leave the winch mounting bolts loose, so I guess I will try to loosen them and then try again. But currently, it doesn't matter what kind of extension or wobbly is used, since the socket itself won't even fit onto the nut with the winch there. I can start the nuts by hand on 3 of the four bumper studs, but the socket won't fit. But the flange nut on the top right side won't even start--the flange runs into the winch. So I guess the only way is to loosen it enough that you can kind of shift the winch from side to side to tighten the nuts. I'm a little bit skeptical it will even shift far enough from side to side, but I guess it's worth a try.[/QUOTE]Yes, it is tight on the inner bolts, but you can get to them. The top inner two nuts can be reached with a 6" extension from the top of the bumper. For the two lower inner nuts, you need to leave the winch mounting bolts slightly loose until after you tighten the front bolts. Those need to be reached with a long extension from underneath.
Perhaps I will need to buy a thin wall socket to try instead of my standard deep well socket. Although, the winch is going to have to shift by more distance than the thickness of my socket wall in order to fit the flanged nuts on both sides.We somehow placed our winch perfectly and though it was tight, we were able to get to both lower nuts with a thin wall socket and a wobbly.
Thanks for the feedback.
Something else that might help others--I opted for the 1.5" Factor 55 fairlead. Using this fairlead, the 40mm mounting bolts provided by Grimm are not long enough to engage the nylon in the locknuts on the opposite side. I found some similar stainless button head bolts on Amazon that are 50mm and hoping that those work.
