Got 392 Wheel Questions?
treillw
Montana
Jeep Grand Cherokee
Anybody have a set of 392 wheels they would like to get rid of?
treillw
Montana
Jeep Grand Cherokee
Has anybody nailed down the offset on these wheels?
I've seen a bunch of threads with discussions on it, but no concrete info.
Are they the same as the stock Rubicon wheels?
Hpc3
Hal
SC
Wrangler(s)
+44mm offset, 17x7.5
Rob97RR
Rob
Northern 'burbs' Chicago, IL
22 392 XR Rubi, 2023 C8 Corvette Z06 & 2023 Ducati
Stay at home dad to 2 munchkins, best job in the world!
As Hpc3 noted, the standard 392 wheels are 17x7.5 and have a +44 offset, so it has about a six inch backspace, (which is the same as the standard, non-392 Rubicon wheels.)
The 392 XR wheel for comparison has a ~4.5 inch backspace, (not sure what the official offset on those are since they are 1/2 inch wider I believe at 17x8, and because it’s almost 4 am here, so my brain is too tired to “math” right now ?) so they stick out at least an inch and half more.
(Hence the little 1.5 inch fender flare extensions that come on the XR model.)
Hopefully someone can chime in with what the offset is on the XR 392 if you need it.
There also websites with wheel spacing calculators you can Google, that you can just enter the wheel size of 17x8 with a 4.5 inch backspace and it will tell you what the offset is.
Hope this helps!
-Rob
2nd 392
Ca
Please inform the ignorant— does the trim ring need to be taken off to change the tire?
DGT
Doug
Kanab, UT (Southern Utah)
2022 JLUR Diesel
The 2022 Rubicon XR (not the 392 XR) stock wheels are 17x8, +12ET, 4.97" backspace. This is different than what others have mentioned
Jeep Wrangler JL Got 392 Wheel Questions? IMG951552_20220107_160020
RobbyR
Robby
Paris, Texas
2022 Rubicon 392
I just pulled off a full set of (5) 17x7.5" 2022 Rubicon 392 Beadlock Capable with BFG LT285/70R17 tires. They are brand new take-off's. I haven't had a chance to take any good photos yet. $2,500 for the complete set.
Jeep Wrangler JL Got 392 Wheel Questions? 2022 Rubicon Wheels
Rob97RR
Rob
Thanks for pointing that out, I may be wrong about the backspacing on the 392 XR as well then. Might just be ~1 inch less than the base 392, not 1.5 like I thought.
Hpc3
Hal
SC
Wrangler(s)
That's ~1.25" so... you're still close =)
