GMRS radio wired to aux switch: good or bad?
tomd
Tom
Wisconsin
21' JL
I read from some purists (radioreference site) that ground must be to chassis, power to battery, etc.
others on Jeep forums seem to support splices and other wiring options.
Anyone here have first hand experience with wiring via aux?
Mikester86
Michigan wishing I was on a trail...
www.jlwranglerforums.com
2020 Jeep JLU Rubicon
If you have a JL with the trailer tow package and the factory switches, there is internal wiring (passenger side floor board area) and external wiring (under the hood).
I would think it is best to go right to the battery. When I installed my CB, I used the internal wiring and one of them goes straight to the battery and is always hot (not on a switch), and used a ground location passenger side floorboard.
Just need to remember to power off whatever device is connected directly, just as you would need to remember to move the switch to the off position.
I am interested to see what others have to say on this subject.
tomd
tomd
Tom
Wisconsin
21' JL
thanks. Yes, (I forgot to specify) via the factory 4 aux switches. I did see on another thread these switches can be switched or battery via unconnect programming.
dpike
New Jersey
'20 JLUR
those aux switches are pretty prime real estate i'd find a little less versatile of a power connection. i tapped my gmrs to the front lighter port with a splice p'n'p' connector. it works fine.
tomd
tomd
Tom
Wisconsin
21' JL
Good suggestion, thanks
Vahdettin
Vahdettin
Seattle, WA
2018 JLU
I have a ham VHF/UFH radio and not GMRS but for this question, there should be no difference. Mine is supposed to be wired straight to battery on both sides but IMHO that is overkill and I suspect manuals say that mostly to keep things simple and to ensure that there will never be a "rush" of power from a switched circuit at ignition time. Also, some older electronics still require a tiny bit of current to hold settings in memory.
Either way, I have my radio wired to AUX 1 on hot and to the chassis mount in the passenger foot sidewell for ground and it works just fine, both from a transmitting perspective and safety. Although the radio has it's own power switch, I just like being able to completely disconnect it from power so I don't come back from a week long hike and find my battery dead at the trailhead because of some feature I didn't know the radio had.
St. Simons Island Georgia
2020 JLURD 06 Corvette. 16 FLTRU
Lighthouse Keeper, Retired Electrical Engineer
Good Luck on your install. Take your time. I sold my radio and antenna with my JK and have not figured out yet what to do with my JL. Wiring directly to the battery is generally recommended to reduce interference from the vehicle to the radio, and from the radio to the vehicle.
For some more information about mobile installations:
http://www.arrl.org/automotive
tomd
tomd
Tom
Wisconsin
21' JL
Thanks Jeff. Feedback definitely a concern. Want to do this right
Jim Marsh Chrysler Jeep
