Rb75
- Robert
- Aug 14, 2018
- Portland, Oregon
- 2018 Wrangler Unlimited Rubicon
I also mounted my MX275 in the glove box. I tucked it on the right and pulled it against the plastic with velcro tape.
I ran an RJ45 extension cable to connect to the mic cable. I ran the Midland antenna cable down below, across to the drivers side and through the opening into the engine compartment up above the brake (assuming where clutch would go if I had a manual).
I also used a CoolTech Mic Mount:
Then decided to mount on the front using the CoolTech Front Antenna Mount. And because I'm a bit anal I primed and painted the steel the same color as my JL (5oz spray can of touch up paint was $13).
