Gladiator Sport add Keyless Entry
LSUFAN861
Destin FL
2020 Jeep Gladiator Sport
I purchased a new Gladiator Sport and it has no keyless entry. I'm looking for an aftermarket solution that would have to include actuators to move the locking mechanism and come with a FOB for unlocking. I'm not looking for the passive to change out the handles, I just want too be able to unlock with a FOB. I've searched the forum and only see passive requests. Thank you in advance.
Jake
Jake
Charleston,SC
Gladiator Sport
Suggest that you call some aftermarket car stereo companies. They can do this for you. Also try Best Buy. And FYI I also have a base Sport model like yours, manual windows, mirrors and locks. It now has Sport S wheels on it.
LSUFAN861
Destin FL
i have the exact same one, but automatic and I love it compared to my old JK I had. Just missing the keyless entry. Thanks for the info.
lrtexasman
Larry
Dallas, TX
Tahoe
Check the JL forum. There are guys on there that have added power locks and have step by step directions.
Mr._Bill
Bill
North Las Vegas, NV
2020 Jeep Gladiator Overland - 2013 Nissan Leaf SV
Check the Mopar store. I think there's a Remote Entry kit that is available.
Jake
Jake
Charleston,SC
Gladiator Sport
I checked the Mopar site, scrolled down and looked at all accessory items available for the Gladiator and did not see any such item listed. I do know that car stereo shops can do this for about $500 for all 4 doors and a lock/unlock key fob.
Mr._Bill
Bill
North Las Vegas, NV
Yeah, I went back and looked. It's a Remote Start kit that is available.
Gatorized
ME/NH
‘06 CRV, ‘14 Mazda3, ‘20 JTR (Gator)
Does the sport have the option to auto lock the doors when you hit a set speed? Would indicate the actuators are already there. The aftermarket remote start might add the door lock function as might the mopar option.
Jake
Jake
Charleston,SC
Gladiator Sport
Interesting question but I highly doubt it. Never heard of that idea for a base Sport model. I don’t think Jeep would offer that for a base Sport truck. I think their idea was to offer a bare bones, no frills truck at an entry price and to offer very few options to keep it along the lines of a bare bones truck. I would have gotten that option if it had been available.
Gatorized
ME/NH
Did they put lock stems sticking up in the corner of the door or do you have the same lock switch by the inside handle as on all the other models?
lrtexasman
Larry
Dallas, TX
Tahoe
This is the write up i was referring to in earlier post from the JL Forum from user RubenZ
https://www.jlwranglerforums.com/forum/threads/installed-power-door-locks-to-my-jl-sport.16398/
"Now I'm by no means a Technical Report writer so use this more as a guide. I can reply here to any questions you may have.
Power Lock Install for JL Wrangler Sport
Introduction
Power Door Lock Install on Jeep Wrangler JL Sport is a project I didn’t anticipate doing until I used my jeep for a few weeks without power locks. It got annoying real quick and I wish Jeep wouldn’t be so cheap and make this a standard option across the trim levels. One thing I will say about this project is take your time!! These vehicles are filled with plastic pieces that will break if you rush it and just try to pop everything off in a hurry.
Parts Needed
  • OEM Door Latch from a JL Wrangler with Power Locks. You only need the 4 doors as the Swing Gate already has power latch. You can purchase these pretty much from any Mopar parts website. I got the below Part numbers from All Mopar Parts:
    • 68250661AC
    • 68282954AA
    • 68282961AA
    • 68282960AA
  • Keyless Entry Alarm & Door Lock Relay Module. The Door Relay Lock Module is needed for the Actuators to function. As for the Alarm you can pretty much go with any aftermarket alarm that offers keyless entry. I chose the:
  • Door Actuator Wiring Jumper – Since you will be installing an Actuator with Power Lock abilities you need to use the wiring jumper for Power Locks. The SPORT wiring jumper only contains 2 wires which just tell the jeep if the door is ajar. The Wiring jumper for a power lock jeep contains 4 wires for the 3 non-driver doors. The driver door uses a 8-pin wiring jumper. I will explain what I did with these further down.
    • Wiring Jumper Part Number: 68351170AA
  • Electrical Crimp Connectors
  • Some Automotive Wire – You can use 18-20gauge wire. I would get 2 different colors so you can have 1 color for the unlock wire and 1 for lock. I ended up having to get 50ft rolls for each color. Then a 25 ft roll for the wire needed to go from Battery to Alarm Module.
Tools Needed
  • Torx Bits (Sizes T15, T20, T30)
  • 10mm Socket
  • Needle Nose Pliers
  • Wire Stripper – Irwin Self Adjusting Wire Stripper. I can’t recommend this one enough!!
  • Wire Cutters
  • Auto Trim Removal Tool Kit – This is optional if unless you want to break some plastic off your new jeep. I tried one door without them but it was scary and I broke a plastic clip in doing so.
  • Various Screw Drivers
Step One – Door Trim Panel Removal
  • Door Trim Panel Removal PDF Document will explain how to Remove the Door Panel. This is where yo will use the Torx 30 for the bigger bolts and the smaller Torx 15 for the bottom screws: Door Trim Panel Removal
**NOTE**Pay close attention to where the Plastic CLIPS are in the Diagram. This is where you will need to use the DOOR TRIM Removal tool to snap them out.
Step Two – Inner Door Plate Removal
  • After you have removed the Door Trim Panel, you can remove the inner Door Plate. For the PDF document on removing the inner door plate Click -> Inner Door Plate Removal
    • You will need a 10mm socket to loosen the bolts that retain the Inner Door Plate & Window. Once you have lifted the window up, you can hold it up with DUCT TAPE. I used some of the Door Trim Removal Plastic Tools and wedged them in between the glass and Rubber on the door.
    • *NOTE* For the Front Doors I honestly didn’t need to remove the handle as suggested. For the Rear Doors you will.
Step Three – Door Latch Removal and Install
  • Once you remove the Inner Door Plate you will have access to the Latch. Be very careful remove the latch from he Plastic Parts it is connected to. They will break.
  • For Detailed PDF on switching out the door latch CLICK HERE -> Front_Door-Latch_Removal
*NOTE* You will see TABS that hold the Latch (#4). On the other side, you can insert a small screw driver to release the clips.
Step Four – Repeat Steps 1-3 for all other doors
  • The Steps are pretty much similar for the other 3 doors. The only difference is the Rear Doors you will have to remove the Handle. To remove the handle you will need to move the rubber door seal and access a small hole there with a Torx T20 Screwdriver. This is not my youtube video but it give you an idea of how to do it.
  • Once you have completed all the doors, do not replace them yet. You need to do the wiring.
Step Five – Wiring the Jumpers
I’ll try not to make this so lengthy as its pretty straight forward and I will include the actual JEEP Wiring diagrams at the end of this post so you can use as reference. Basically the new Wiring Jumpers you will get have 4 wires. Now surprisingly the colors will be different as they are wiring jumpers for a Wrangler with Power locks from he factory so they different. But all you need to know is the ORDER they go in the connector. So for example the Jumper you get will look like this:
You only need to concern yourself with the order of the PINS and not the colors as the colors will not really match up to your wires you bought. The first Green one is PIN 1 and the last Violet/Purple is Pin 4. So Pin 1 is UNLOCK and Pin 2 is LOCK and the other 2 need to stay in same order with what your about to do next.
Now basically when you buy the Wiring Jumpers, your only using them for parts. You won’t actually connect them in their complete form to your lock actuators. For example, the 3 doors that are NOT the driver have different plugs from the factory so you are going to remove the wires from the jumper you bought and place that connector onto your jeeps. To do this:
  1. Undo all the tape that holds the wires together on the new Wiring Jumper you received.
  2. Next you will need to remove the connector from he wiring pins. To do this, you will need to slowly put a screwdriver where I have the RED ARROW and lift that plastic. It will reveal the Wiring PINS.
  3. Using your nail or small screwdriver you will push down on the pins and pull the Black and Violet/Orange out. Leave the Green ones in there.
  4. Cut the wires close to the OPPOSITE SIDE connector.
  5. So basically you should be left with the above Connector with the 2 green wires (about 6″ in length) and 2 empty slots from he wires you remove.
  6. Now you can go to your jeeps Latch Wiring harness and plug the new wiring Jumper to your existing harness the same way. It should be pretty straight forward. Basically the reason your doing it this way is to not have to under the wiring loom front he factory harness.
  7. Now you can wire in your new WIRE you bought to the LOCK and UNLOCK wires on the new jumper. Remember Pin 1 is Unlock and Pin 2 is Lock. So for example, I used a Green Wire for Unlock and White for Lock. That way I keep it consistent for all doors and when I plug it into the Alarm Relays its easier to remember.
  8. Now just zip tie or use electrical tape to run the wire along the factory wiring harness and through the door wiring loom on the jeep.
Make sure you leave enough slack for all doors to reach under the steering wheel where you will mount the alarm module.
Repeat the Above steeps for all other doors. For the Driver door you don’t need to replace the switch. you can just remove the extra pins that you will have left over from the other jumpers and add them to the connector. For some reason the driver side connector doesn’t need to be replaced like the other doors. So just get 2 extra wiring pins you will have left and they will go on pins 5 & 6
After you’ve done the above steps and left enough wiring slack you can pretty much put the doors back together same way you took them apart. Go slow and take your time. Connecting the rods back to the latch is tricky for the front doors if you opt NOT to remove the handle piece.
Step Six – Wiring the Alarm System/Keyless Entry
This is entirely up to you but I opted to really just use this alarm for the Door Locks. I probably will wire more of the security features at a later date like Door Trigger alarm, aux swing gate unlocks, etc. That is why you see that big bundle of wires tied up. So for now lets just focus not he necessities.
Basically you just need the Red Battery Wire, Black Ground wire and then the small little wiring harness on the bottom that plugs to the 451M Door Lock Relay Module. So what I did was run a wire directly to the battery for the RED(Batt) Wire. The Black wire is your typical Ground wire. As for the wires on the Relay here is what you need to do:
Step Seven – Clean up wires
The Rest is pretty self explanatory. Just tuck the wires away neatly behind the plastic trim pieces. The Rear Doors I ran along the bottom plastic trim piece onto floor. For the Passenger Side I ran the rear door wires to the passenger side wires, then spliced wires from there across the center console hump to the alarm module under the steering wheel.
Conclusion
All in all, this took me about 8-10hrs to complete. I know its a lot of information to take in, but once you start removing the door panels etc and look at the wiring jumpers you will start to make sense of what I did and wrote. Also, the other thing that may be annoying is having to have 2 key fobs. However the one from Avital is pretty tiny compared to the jeep one so I hardly know its there and since the Jeep is Push button to start I never have to really get my keys out. I just reach in my pocket and hit the unlock."
Jake
Jake
Charleston,SC
Gladiator Sport
No lock stems in each corner. Have normal lock switch by the inside handle of all doors as on other models. And FYI a local car stereo company told me they could add power locks for all 4 doors along with a key fob for about $500 installed(parts, labor and key fob included). Not certain if it would include a quick disconnect for each door(for when you go doorless) but should be easy for them to do. They would use the same kit that is already available for Wranglers as it’s the same doors and door locks. I may do this.
Jeeperjamie
Jamie
Kannapolis nc
2020 jeep gladiator
Weyerhaeuser
Dan1227
Grandledge
Gladiator sport
I purchased the sport model and it came with remote start. And heated seats and steering wheel forgive my ignorance but I thought all that came standard.
TinyTink
Louisiana
2020 Jeep Gladiator Sport S with Max Tow
I have the Sport S. The remote start is an option - under the Convenience group with the garage door opener, or under the Cold weather Group with the heated seats. Sounds like you have the Cold Weather group.
I do want to clarify that my Remote Start does not include Passive Entry. It says Remote Keyless Entry and a lot of people (myself included) assumed that also meant passive entry, but it does not. (Passive entry is when you get close to the car with the key in your pocket and the doors automatically unlock.) Adding that is an entirely different can of worms, so just be aware that passive entry doesn't come with the remote start. Kind of crazy because if you have the push button start the car recognizes the key is in the vehicle, but the door doesn't.
