- Dan
- Aug 12, 2018
- The 48th State
- 2020 JT Rubicon Launch Edition | 2021 F350 6.7L
- Banned
- #91
So I just wanted to follow up, as I have had a chance to install that relay to ensure both batteries are isolated when the ignition is off. Following Shane's recommendation, I put the relay in line on the brown ground wire connected to the accessory battery.
It does work as expected, but has the side affect of not being able to use the GScreen to monitor battery voltage when the vehicle is off, which is kind of a bummer. So I'm going to look at moving the relay to use one of the power wires connected to the isolator solenoid instead. @Genesis Offroad, any advice on whether it would be a bad idea to do this? Or have any better ideas how to do this and also be able to use the GScreen when the ignition is off?
Result: The batteries no longer drain themselves due to the solenoid drawing 750 milliamps overnight. My accessory battery remains at a constant 12.9 volts when not being used, as expected. And my starting battery is a healthy 12.8 volts every morning.
Complications: Now that my accessory battery is held at the correct voltage, there is an unintended negative side affect related to the IBS being connected to the wrong battery. The IBS will always read 12.9 volts from the accessory battery, even if the cranking battery has been drawn down. This means the alternator will never go into the higher charge profiles. And it sits at 12.9 volts for most of my drive to and from work every day.
If my starter battery were to get depleted, it would not charge back up properly due to the IBS being connected to a full battery all of the time during day to day commuting activities.
So I'm definitely going to move the IBS to the cranking battery as my next step, to resolve this issue.
Thanks Jimmy for working through this. If I understand what you're doing and the results (not likely I really understand it) I look forward to what you find once you've moved the relay to one of the wires connected to the isolator solenoid.
I don't plan on running the Genesis GScreen so perhaps that fact and your modification will be "the solution."
I do hope @Genesis Offroad not only chimes in here but also determines if/how they'll change their wiring for these Jeeps.
