Man-of-methods
Thanks. I’ll try that and see if it gives the same charge volts.Here's the pic, hard to see but you get the idea..
Its always above 14.4v some times high as 14.7 which is even better for agm batteries.Thanks. I’ll try that and see if it gives the same charge volts.
Yeah when I was doing some research I came across your post, thanks! I'm no expert on the IBS and don't know all what the jeep uses in the algorithm etc for the charging duties either. But I have to believe it uses another sensor input on the plus side of the main battery since the IBS is only hooked up to the ground. That other sensor is probably from the main battery which would prove the theory of disconnecting the IBS would send a false no voltage signal therefore inhibiting full voltage charge on the main battery ( or both batteries in the Genesis case).I'm not an expert on the Genesis system, but I think the battery sensor is connected to the wrong battery. It needs to be on the battery to the left, which is the cranking battery, the new Main battery. The battery sensor monitors the current flowing through the battery and having it connected to the accessory battery provides the charging system with incorrect information.
According to the installation video, the batteries are separated during cranking. With the battery sensor monitoring the accessory battery, it will not see the starting current used by the cranking battery. The battery sensor not reporting accurate power usage may be why the charging system is having issues.
Here's my post with the information I was able to find about the battery sensor.
https://www.jlwranglerforums.com/forum/threads/3-6l-ess-ibs-information.22585/
I'm pretty sure that's the only battery sensor. Current flows from the positive terminal to the negative terminal, it's measuring the current at the negative terminal.Yeah when I was doing some research I came across your post, thanks! I'm no expert on the IBS and don't know all what the jeep uses in the algorithm etc for the charging duties either. But I have to believe it uses another sensor input on the plus side of the main battery since the IBS is only hooked up to the ground. That other sensor is probably from the main battery which would prove the theory of disconnecting the IBS would send a false no voltage signal therefore inhibiting full voltage charge on the main battery ( or both batteries in the Genesis case).
I should have added that unplugging the sensor may be the final solution if the higher charging voltage is what the batteries preffer. I was just pointing out that the battery sensor is not optimally placed as is.I mean you are assuming the current (if being measured) has anything to do with the variable voltage charging alternator algorithm BS jeep uses. Of course the ECU is measuring the POS voltage somewhere to determine the alternator output, probably whatever the ECU is seeing at the time. Who knows this is all assumptions since we don't work for jeep and didn't design the system, I know what works first hand and I am just sharing with others so they may too reap the benefits of an alternator charging constant 14v+.
Sorry if the post came out attitudely I'm a virgo and I'm drinking
Probably because one your batteries are reading low voltage...Whats the battery measuring while vehicle has not been running for 5 min or so? Also no easy way to measure 2nd battery without removing fuse panel cover and probing with a meter.For what it’s worth, I noticed this morning on the way to work that the volts read 14.1 the whole time on the highway. Note, I haven’t unplugged anything and I don’t have the Genesis system.
Mine has been around the mid 14 volt range for the past year that I have been watching. It's not because of bad batteries, it's because of short trips. If I take a long trip, the voltage will go down for a few days, but it eventually goes back up.For what it’s worth, I noticed this morning on the way to work that the volts read 14.1 the whole time on the highway. Note, I haven’t unplugged anything and I don’t have the Genesis system.
Unless you are auto stopped, all voltages are of the combined batteries. If you disconnect the Aux battery ground cable from Main battery negative terminal you can read the individual battery voltages.Probably because one your batteries are reading low voltage...Whats the battery measuring while vehicle has not been running for 5 min or so? Also no easy way to measure 2nd battery without removing fuse panel cover and probing with a meter.
Yes, it does nothing. It is my understanding that when both batteries are at the level mine are it should show “on”.Did you hold the button down while on the "boost off" screen?
