Gears
Cllowe
christopher
Tennessee
2020 2 door jl
Ok I have read and read but can’t find my exact answer. I have a 2 door sport with the 3.6 and 6 speed manual. It has a super lift 2.5in lift with 33 in tires. So I am torn on my gears. Should I go 4.10 or 4.56. I drive a lot of highway and normally cruise about 75. Right now I do that in 5th. My concern is going with the 4.56 and rps being to high on the highway.
jeepdriver99
JD
Central Ohio
18 JLR 2 Door, 21 JLU TD, 06 GC, 54 Willys SW
Retired, W8BWD
I am guessing since yours is a Sport, that you currently have 3:72 gears. My 2 door Rubicon, 3.6 with 6 speed manual, came with 4:10 gears and 33 inch tires. I thought that was a great combination. My wife's 4 door JLU Sport has the 3:72 but with an Eco Diesel and those work well for her especially on the highway.
SH556JL
Steven
Florida/Georgia
21 JLR M6 RIP, 23 JLR M6
I would look into getting some Rubicon take off axles and put them on. I seen a few used on and off over the past year. Doesn’t seem like it would be much more then the cost of new gears and get stronger axles.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
That depends on what altitude you live at and what kind of off roading you do. If you're in an area with a lot of hills the shorter gears (higher number) are better. In the flat lands taller gears (lower numbers) are good.
High altitude, rock crawling, towing, and hills all want shorter gears. Future plans also come in to play. Will you go to 35s? Then 4.56s are the better choice. If you're not going to 35s and you don't do anything that needs shorter gears, 4.10s would work.
Parting thought. The 3.6 Pentastar is an engine that likes to rev. Don't be afraid of higher RPMs on the highway.
blnewt
New Mexico
Just ask @cosine he knows!
Nice reply!
If plans are to stay w/ 33s then Rubicon takeoff axles become very attractive.
Here's a couple prices on brand new crate axles, if you get the pair at the same time you can save quite a bit on shipping.
https://www.mymoparpart.com/p/75452408/77072405.html
https://www.mymoparpart.com/p/75452409/77072406.html
By the time you were to change gears, add lockers, and strengthen the smaller sport axles you're going to spend as much or more, and FWIW the Sport sets are 3.45:1 gearing.
jeepdriver99
JD
Central Ohio
Retired, W8BWD
Nice reply!
Also need to add in the cost of updating the tire size to the computer. I had the dealer do it for a little over $100.00 but others get a Tazer or JScan to update it.
blnewt
New Mexico
And switches/wiring to control the e-lockers, and I believe a new track bar, so there are a few more costs to consider for sure. I think the rear crates come w/ brakes but the fronts don't (AFAIK) so you'd have to use sport front brakes or get a Rubicon front set.
SH556JL
Steven
Florida/Georgia
Quick look on eBay, you can get a set of Rubicon axles for about $3,000-3,500 and I imagine you can get about $1,000 for the stockers.
Cllowe
Cllowe
christopher
Tennessee
2020 2 door jl
I can have the re gear done cheap. Like parts at cost and no install so I would rather just do the re gear and not axel swap.
blnewt
New Mexico
that sounds like a cost effective plan, nice!
At Risk Ute
Christian
milehightrails.com
‘94 YJ, ‘21 JLR, ‘22 JLUR XR, ‘23 392 XR
Retired Navy
I went with 4.10 gears on my ‘19 2 door Sport (3.6L / 6MT) after going to 33s. Felt perfect on the Highway.
Cllowe
Cllowe
christopher
Tennessee
2020 2 door jl
At what rpm are you running at say 70 or 75mph?
