Gas on/under the car
frankmorris
Albuquerque
2019 JLU
I'm almost positive this is a stupid question, but humor me:
This evening, I drove through some sort of gas spill, which resulted in gas on the back of my car and underneath as well. I've managed to get the gas off the back/sides of the car at the self car wash, and gave the undercarriage a good power spray, but I'm wondering if it's harmful if I didn't get it all off? I understand the road has oil, gas, etc. and I'm constantly driving through it, therefore getting that stuff on the bottom of the car anyway, but it's not generally a spraying of it like I had tonight.
Should I get under there and do a more thorough cleaning, or is it okay to be down there? You know, new car and all....
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Since you already gave it a good power spray.
You’ll be fine.
DaltonGang
Houston, Tx
It's all good.
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
Did this happen to your new Car or your new Jeep?
just giving you heck. We don’t call them cars.
Sounds like you got your Jeep taken care of.
Maverick909
Inland Empire
www.instagram.com
only thing i would do differently is many a little 303 aerospace protectant or a plastic shiner under the wheel wells and on the plastics just to help keep the fuel from drying them out. should be fine otherwise!
Rploaded
Houston
2019 JLUR
You did perfectly, you drive through all sorts of stuff on a daily basis. Rinsing it off the visible areas was a good move. Enjoy your Jeep, next time it rains and you’re driving anything else will be washed away.
cbrenthus
FL
'19 Mojito JLUR
Gas also evaporates pretty quickly, as stated, you're fine ;).
Carlton
Chicago
Jeeps lots of jeeps
Rinsing it off was more than enough. It would have evaporated if you hadn't.
A bit unrelated, but reminds me of a funny story.
In high school, let's just say that I didn't have the brightest girlfriend. We went to the gas station and she said she would pump the gas. She was out there for a while. I started smelling gas strongly, I also heard the pump turn off multiple times. I didn't think much of the pump turning off because it was common with that car.
When I smelled the gas, I knew something wasn't right. I look out and there was gas pouring down the side of the car and a puddle easily twice the size of the car on the ground...
I got out, told her to turn off the pump, and asked what she was doing. She said, "The gas keeps coming out." I informed her that this was due to the tank being full. She laughed and said "ooooooh." I asked her why she didn't stop. Her response was " You told me to put $10 in...."
Gas was less than $1 at the time. I probably ended up with 5 gallons in the tank and 6 gallons on the ground....
jeepdabest
Bobby
Arizona
2019 JL Sahara
Happened to us in the dark. We got underneath and lit my Zippo but found no gasoline.
dsgrey
Kevin
2019 JLU
It should be fine. I had a work truck in the early 80's - 1/2 ton Chevy with a diesel. Back when Chevy just cheaply converted the 350 gas engine to a diesel with no further considerations. Every 200 mile run would leak 2 quarts of oil since the engine wasn't actually designed for this use. All that oil went down and sprayed the underside of the truck, tailgate and probably anyone closely following. When I left it had close to 200k miles and no issues other than it smelling like oil and diesel.
fat_head
2018 JLU
Check your fuses to make sure they are all seated. Also check tire PSI
frankmorris
Albuquerque
2019 JLU
Thanks everyone! I appreciate the humor and people giving me a hard time. Good to put my mind at ease. And sorry for the delay - I guess I hadn't marked this forum as wanting to follow it, so hadn't been getting updates.
