CantThinkOfAHandle
Sorry. There were some posts wondering if the JL auto might have a dual clutch, and disappointment to learn it does not. (I hope I got that right.) I posted merely to comment that DCTs seem to be falling out of favor, and also that I liked the ZF in my BMW. I have no idea why I referred to it as having a single clutch. Can I blame a head cold? Thanks for correcting my error.Don't want to nitpick, but you're mixing terminology and it may be confusing to some. The ZF 8-speed in your BMW is a conventional automatic with a planetary gearset and a fluid-based torque converter (it does not contain a friction-based clutch). The same as the automatic offered in the JL.
DCT's employ constant-mesh gearsets (similar to a manual transmission) and then 2 wet (or dry) friction clutches. There were single-clutch semiautomatic transmissions in the early 2000's (mostly in exotics and high-performance vehicles), but these have since fallen out of favor.
For off-pavement purposes, I find it nice to have a torque converter to soak up driveline shock from jumpy throttle application. That's the one thing I don't like about driving manual Jeeps on faster washboard dirt roads.
And thanks also for relating your experiences with manual and auto Jeeps on dirt roads, since I use back roads a lot. In countless hundreds of miles driving dirt roads, I've never navigated them with an auto, and have worried I might miss engine braking with an auto Jeep. I assume that has not been a problem for you? You don't let your foot off the gas in advance of sharp corners and find yourself hurtling into the abyss?
