If that were true, then premium wouldn't be required.Like I said, nothing will happen if it has 89 or 87 put in. The computer will adjust the parameters accordingly.
What do you think happens if you run 87?If that were true, then premium wouldn't be required.
My supercharged Z06 “requires” 93 octane or higher. Do you know what happens if I’m somewhere that doesn’t have 93 or higher & I have to put in, *gasp* 89 or even 87? Nothing. Will I drive around doing WOT pulls, no, but my engine won’t suddenly explode because I had to use a lower octane fuel for a tank.If that were true, then premium wouldn't be required.
Easy fix- just pickup a small stencil kit and mark it, Label maker will eventually come off due to heat or extreme cold. Keep the Jeep wave going.The 392 requires premium gasoline. The gas cap looks like every other JL cap and makes no mention of octane. At least mine doesn't. I'm afraid if I let someone else drive it they'll refill it with regular to "do me a favor" since you can watch the gas gauge drop while you drive it.
Are any aftermarket caps available that mention 91 octane? Or am I going to have to do something really ugly with my label maker?
Not trying to argue or cause any problem. With that said, that hasn’t happened to me yet but I only have 3500 miles on my 392. Where I live 85 is normal and some places don’t have 90 or 91 octane. Not that there are a lot of gas stations here anyway.Knocks and pings...not gonna test it to find out.
Why do you think required doesn't mean 'required'?
Yeah, I liked Colorado but the fuel choices are bogus.Not trying to argue or cause any problem. With that said, that hasn’t happened to me yet but I only have 3500 miles on my 392. Where I live 85 is normal and some places don’t have 90 or 91 octane. Not that there are a lot of gas stations here anyway.
“Required” is stated a few times In the manual. In fact there is a requirement for a brake fluid spec in the owners manual that doesn’t exist. The door plate says to inflate tires to 37 psi, I run 30. I do follow what are “safety” requirements, at least in my opinion.
I don’t skimp on fuel…. I could purchase 110 octane avgas since there is a small airport. But on 87, my local ”premium“ it runs great. So technically I am running premium…. But it is 87 octane.Yeah, I liked Colorado but the fuel choices are bogus.
Brake fluid and tire pressure have nothing to do with fuel requirements.
Accurate manual or not, why buy a 392 and skimp on the fuel?
Additionally, knowing dealers' penchant for blaming the customer, I'll avoid that excuse.
If 87 octane is your premium, what's your regular? That's the lowest regular unleaded grade offered here, with 91 or 93 being the most common premium grade available (and usually another grade or two in the middle).I don’t skimp on fuel…. I could purchase 110 octane avgas since there is a small airport. But on 87, my local ”premium“ it runs great. So technically I am running premium…. But it is 87 octane.
85 is regular at the pumps here.If 87 octane is your premium, what's your regular? That's the lowest regular unleaded grade offered here, with 91 or 93 being the most common premium grade available (and usually another grade or two in the middle).
