My question is rear lower control arm front bolts ft. lbs. so which one is the right torqueTorque Specs for the 2018 Jeep Wrangler JL Steering Related Components
Neither. The correct way to read that chart is you torque it to 74 ft. lbs. and then continue for another 50 degrees of rotation.My question is rear lower control arm front bolts ft. lbs. so which one is the right torque
74 or 50 ?
Yes, but i'm using stock control arms so want to know what is the torque specs stock front and rear control arms and tracbar and sway bar link?Neither. The correct way to read that chart is you torque it to 74 ft. lbs. and then continue for another 50 degrees of rotation.
I don't have the correct tools to know that I've turned the fastener another 50 degrees. What I have done is research aftermarket websites (such as Synergy, Rock Krawler, etc.) and found most aftermarket parts suppliers list 190 ft. lbs. for front and rear lower control arms. That's what I go with.
